On second thought, I may see a problem after all…
mrf-TEST-EVG0:TrigEvt4-Enable-RB Enabled
mrf-TEST-EVG0:TrigEvt4-EvtCode-RB 0
It looks like you are using trigger 4 to send the event, but the event code you are “sending” is 0 — which is the “null” event. I think it should be set to “4” if you want the EVR to see an event 4.
-Bj
- Event triggers for plusers not detected (mrf-timing system) Karim Laihem
Re: Event triggers for plusers not detected (mrf-timing system) Bjorklund, Eric A
modbus: problem on readInt32Array Davide Marcato
<2017>
How to migrate old data from channel archiver to archiver appliance Heinz Junkes
<2017>
ANJ, 21 Dec 2017 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
