Abdalla:
On 12/13/2017 2:04 AM, Abdalla Ahmad wrote:
> How to save mca record waveform data into any of the following formats:
> MCA, HDF5, NXS?
Attached is an example using Python with the PyEpics package to read the
MCA waveform, and h5py to write the HDF5 NeXus file. You'll need to
change the PV in the code to one of yours, of course. The waveform is
stored in the HDF5 file at this address:
/entry/instrument/detector/waveform
but it is also available, by using an HDF5 hard link, at
/entry/data/data
The data is stored using GZIP compression, support for which should be
available with all HDF5 clients. There are other possibilities. The
output format has been validated with the "punx" NeXus data file
validation tool.
I believe this example satisfies two of your three output formats.
You can view the resulting file with hdfview, PyMCA, or NeXPy.
Hope this helps,
Pete
hdfview: https://support.hdfgroup.org/products/java/hdfview/
PyMCA: http://pymca.sourceforge.net/
NeXPy: https://nexpy.github.io/nexpy/
punx: http://punx.readthedocs.io
Hi
MCA, HDF5, NXS?
Best Regards,
Abdalla Ahmad
Control Engineer
SESAME
Allan, Jordan.
Tel: (+962-5) 3511348 , ext. 265
Fax: (+962-5) 3511423
Mob: (+962-7)88183296
www.sesame.org.jo <http://www.sesame.org.jo/>
Pete R. Jemian, Ph.D. <[email protected]>
Beam line Controls and Data Acquisition, Group Leader
Advanced Photon Source, Argonne National Laboratory
Argonne, IL 60439 630 - 252 - 3189
Education is the one thing for which people
are willing to pay yet not receive.
import numpy as np
import h5py
import datetime
def write_nexus_file(fname, waveform, md={}):
write the waveform to a NeXus HDF5 data file
Parameters
fname : str
name of the file (relative or absolute) to be written
waveform : numpy array
the MCA waveform data
md : dictionary
key: value where value is something that can be written by h5py
(such as str, int, float, numpy array, ...)
nexus = h5py.File(fname, "w")
nexus.attrs["filename"] = fname
nexus.attrs["file_time"] = str(datetime.datetime.now())
nexus.attrs["creator"] = "write_nexus_file()"
nexus.attrs["H5PY_VERSION"] = h5py.__version__
# /entry
nxentry = nexus.create_group("entry")
nxentry.attrs["NX_class"] = "NXentry"
nexus.attrs["default"] = nxentry.name
# /entry/instrument
nxinstrument = nxentry.create_group("instrument")
nxinstrument.attrs["NX_class"] = "NXinstrument"
# /entry/instrument/detector
nxdetector = nxinstrument.create_group("detector")
nxdetector.attrs["NX_class"] = "NXdetector"
# /entry/instrument/detector/waveform
ds = nxdetector.create_dataset("waveform", data=waveform, compression="gzip")
ds.attrs["units"] = "counts"
ds.attrs["target"] = "/entry/instrument/detector/waveform"
# /entry/data
nxdata = nxentry.create_group("data")
nxdata.attrs["NX_class"] = "NXdata"
nxentry.attrs["default"] = nxdata.name
# /entry/data/data --> /entry/instrument/detector/waveform
nxdata["data"] = nexus["/entry/instrument/detector/waveform"]
nxdata.attrs["signal"] = "data"
if len(md) > 0:
# /entry/instrument/metadata (optional, for metadata)
metadata = nxinstrument.create_group("metadata")
metadata.attrs["NX_class"] = "NXcollection"
for k, v in md.items():
try:
metadata.create_dataset(k, data=v)
except Exception:
metadata.create_dataset(k, data=str(v))
nexus.close()
if __name__ == "__main__":
demonstrate how to use this code
Read MCA waveform from EPICS.
import epics
waveform = epics.caget("ioc:mca1")
extra_information = dict(
pv_name = epics.caget("ioc:mca1"),
bitcoin_value="15000", # just an example
write_nexus_file("example.h5", img, md=extra_information)
- Save MCA record data Abdalla Ahmad
Re: Save MCA record data Mark Rivers
<2017>
<2017>
