Hello,
I have migrated an archiver appliance from one machine/filesystem to another
machine/filesystem. Everything works fine except I can not retrieve values
from within CSS. Must be a missconfiguration.
Searching for the reason, I found a bug in the sample startup script.
In the startup function:
function startTomcatAtLocation() {
if [ -z "$1" ]; then echo "startTomcatAtLocation called without any
arguments"; exit 1; fi
export CATALINA_HOME=$TOMCAT_HOME
export CATALINA_BASE=$1
echo "Starting tomcat at location ${CATALINA_BASE}"
ARCH=`uname -m`
if [[ $ARCH == 'x86_64' || $ARCH == 'amd64' ]]
then
echo "Using 64 bit versions of libraries"
export LD_LIBRARY_PATH=${CATALINA_BASE}/webapps/engine/WEB-INF/lib/
native/linux-x86_64:${LD_LIBRARY_PATH}
else
echo "Using 32 bit versions of libraries"
native/linux-x86:${LD_LIBRARY_PATH}
fi
pushd ${CATALINA_BASE}/logs
${CATALINA_HOME}/bin/jsvc \
-server \
-cp ${CATALINA_HOME}/bin/bootstrap.jar:${CATALINA_HOME}/bin/tomcat-
juli.jar \
${JAVA_OPTS} \
-Dcatalina.base=${CATALINA_BASE} \
-Dcatalina.home=${CATALINA_HOME} \
-cwd ${CATALINA_BASE}/logs \
-outfile ${CATALINA_BASE}/logs/catalina.out \
-errfile ${CATALINA_BASE}/logs/catalina.err \
-pidfile ${CATALINA_BASE}/pid \
org.apache.catalina.startup.Bootstrap start
popd
Here LD_LIBRARY_PATH gets set to an invalid path, as CATALINA_BASE is set from
the parameter passed to the function:
which is called like:
startTomcatAtLocation ${ARCHAPPL_DEPLOY_DIR}/mgmt
So in the end the path looks like:
${ARCHAPPL_DEPLOY_DIR}/mgmt/webapps/engine/WEB-INF/lib/native/linux-x86...
But the real PATH here should be
${ARCHAPPL_DEPLOY_DIR}/mgmt/webapps/mgmt/WEB-INF/lib/native/linux-x86...
The archiver still works without the LD_LIBRARY_PATH set correctly.
Jörn
Re: caget() from C++ Mark Rivers
Macro for ImageJ running in headless mode for the AreaDetector plugin? David Michel
<2017>
Re: Recommendations for EPICS Based Data Acquisition System Peter Milne
Re: Bug in sampleStartup.sh of archiverAppliance? Shankar, Murali
<2017>
