Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: RE: EPICS 7 Release Candidate 1
To: 'Andrew Johnson' <anj@aps.anl.gov>, EPICS tech-talk <tech-talk@aps.anl.gov>
Date: Thu, 7 Dec 2017 00:00:18 +0000
Folks,
I have successfully built base 7.0.1-rc1, and all of the synApps modules (including asyn, seq and areaDetector) on the following architectures:
linux-x86-64 (Centos 7)
linux-x86 (Centos 7)
windows-x64-static (Visual Studio 2010)
vxWorks-ppc32 (VxWorks 6.9.4.1)
I had to make minor changes to the following modules:
motor
camac
areaDetector
    ADCore
    ADPointGrey
    pvaDriver
These changes have been pushed to the master branch for these repositories on Github.
I applied the following patch to base-7.0.1-rc1 in order for the Windows builds of dxp and quadEM to succeed.  Thanks to Andrew Johnson for this.
diff --git a/src/tools/EPICS/Release.pm b/src/tools/EPICS/Release.pm
index bceed2e..2b9cc1f 100644
--- a/src/tools/EPICS/Release.pm
+++ b/src/tools/EPICS/Release.pm
@@ -46,7 +46,7 @@ sub readRelease {
     my ($file, $Rmacros, $Rapps, $Rdone) = @_;
     # $Rmacros and $Rdone are hash-refs, $Rapps an array-ref
-    if (exists $Rdone->{$file}) {
+    if ($Rdone->{$file} > 0) {
         die "Release.pm: Recursive loop found in RELEASE files,\n" .
             "discovered in $file\n";
@@ -83,6 +83,7 @@ sub readRelease {
     close $IN;
+    $Rdone->{$file}--;
There is still a problem building with more recent releases of Visual Studio (2013, 2015, 2017).
Thanks to the core developers for their hard work on this.
> -----Original Message-----
> From: tech-talk-bounces@aps.anl.gov [mailto:tech-talk-bounces@aps.anl.gov] On Behalf
> Of Andrew Johnson
> Sent: Friday, December 01, 2017 5:37 PM
> To: EPICS tech-talk
> Subject: EPICS 7 Release Candidate 1
> The Core EPICS developers are proud to belatedly announce that the first
> (and hopefully only) release candidate version of EPICS 7.0.1 has been
> tagged and tarred up and is available for download and testing from the
> EPICS website:
>     http://www.aps.anl.gov/epics/base/R7-0/1.php
> Anyone who has built past EPICS Base releases should have no difficulty
> in configuring and building this release from the tar-file, the process
> is the same as before although internally the layout of the source code
> is a little different. This was done to integrate the EPICS PVA modules
> (formerly referred to as EPICS V4 C++ modules) into the build, so while
> the complete build takes longer the result now includes support for the
> new pvAccess network protocol.
> Unfortunately our release documentation is still woefully incomplete.
> We want to make the final 7.0.1 release in just over a week's time, so
> please report any problems and send any questions here to tech-talk as
> soon as possible. The developers will try to answer them as soon as we can.
> - Andrew
> Arguing for surveillance because you have nothing to hide is no
> different than making the claim, "I don't care about freedom of
> speech because I have nothing to say." -- Edward Snowdon
EPICS 7 Release Candidate 1 Andrew Johnson
Prev: RE: EPICS 7 Release Candidate 1 Mark Rivers
Next: Re: caget() from C++ Church, Eric D
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Next: Set the PV value in different interface through script xus
ANJ, 06 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
