1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS 7 Release Candidate 1
To: Michael Davidsaver <[email protected]>, "Peterson, Kevin M." <[email protected]>, "Johnson, Andrew N." <[email protected]>, EPICS tech-talk <[email protected]>
Date: Wed, 6 Dec 2017 13:44:26 +0000
Hi Michael,
Following the MSDN link in your message it says that the option /std:c++14 is supported in VS2015.  In fact it says this:
The /std:c++14 and /std:c++latest options are available beginning in Visual C++ 2013 Update 3.
However, I just did some Google searching, and it appears that the line above may actually be a typo, because other sources indicate that this option was added in Visual C++ 2015 Update 3, not 2013.  That would explain why it is not working for me.
I am not sure if it is possible to update the Community Edition 2015 to Update 3, or if I need to install 2017.  Does anyone else know?
Do you plan to require using either 2010 (which works) or 2015 Update 3 or 2017 (assuming they work) for EPICS 7?  Or will the code be changed to work with these older compilers?
From: [email protected] <[email protected]> on behalf of Michael Davidsaver <[email protected]>
Sent: Tuesday, December 5, 2017 9:07 PM
To: Peterson, Kevin M.; Johnson, Andrew N.; EPICS tech-talk
On 12/05/2017 03:17 PM, Peterson, Kevin M. wrote:
> d:\epics7\base-7.0.1-rc1\modules\pva2pva\pdbapp\pdbgroup.h(136): note: see declaration of 'PDBGroupChannel'
> ../pdb.cpp(61): error C2664: 'std::shared_ptr<PVIFBuilder>::shared_ptr(std::shared_ptr<PVIFBuilder> &&) noexcept': cannot convert argument 1 from 'std::auto_ptr
> <PVIFBuilder>' to 'std::auto_ptr<PVIFBuilder> &&'
hmm, seems like that MSVC implementation of shared_ptr doesn't have all of the constructor overloads.
Maybe they've just jumped the gun by removing the deprecated (in c++17) form, even when building in c++98?
http://en.cppreference.com/w/cpp/memory/shared_ptr/shared_ptr
Can you try to rebuild everything in >= c++11 mode by adding the "/std" compiler flag?
When built with >= c++11 compatibility, unique_ptr is used instead of (deprecated) auto_ptr here.
https://msdn.microsoft.com/en-us/library/mt490614.aspx
Re: EPICS 7 Release Candidate 1 Michael Davidsaver
EPICS 7 Release Candidate 1 Andrew Johnson
Re: EPICS 7 Release Candidate 1 Peterson, Kevin M.
Prev: Announcing nf_conntrack_epics Michael Ritzert
Next: Re: EPICS 7 Release Candidate 1 Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: RE: EPICS 7 Release Candidate 1 Mark Rivers
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
