Hi Andrew, Thank you for responding - unfortunately I cannot succesfully open 'softIoc.dbd" file for EPICS 3.15.5. Method of execution: *********************************************************************************************** [nrahman@sunfire03]% pwd /u/nrahman/EPICS/base-3.15.5/dbd [nrahman@sunfire03]% ls aSubRecord.dbd compressRecord.dbd mbbiRecord.dbd permissiveRecord.dbd aaiRecord.dbd dbCommon.dbd mbboDirectRecord.dbd printfRecord.dbd aaoRecord.dbd dbCore.dbd mbboRecord.dbd selRecord.dbd aiRecord.dbd devSoft.dbd menuAlarmSevr.dbd seqRecord.dbd aoRecord.dbd devSoft_adj.dbd menuAlarmStat.dbd softIoc.dbd asSub.dbd dfanoutRecord.dbd menuConvert.dbd stateRecord.dbd base.dbd dlload.dbd menuFtype.dbd stdRecords.dbd base_adj.dbd eventRecord.dbd menuGlobal.dbd stringinRecord.dbd biRecord.dbd fanoutRecord.dbd menuIvoa.dbd stringoutRecord.dbd boRecord.dbd filters.dbd menuOmsl.dbd subArrayRecord.dbd bptTypeJdegC.dbd histogramRecord.dbd menuPini.dbd subRecord.dbd bptTypeJdegF.dbd longinRecord.dbd menuPost.dbd system.dbd bptTypeKdegC.dbd longoutRecord.dbd menuPriority.dbd waveformRecord.dbd bptTypeKdegF.dbd lsiRecord.dbd menuScan.dbd calcRecord.dbd lsoRecord.dbd menuSimm.dbd calcoutRecord.dbd mbbiDirectRecord.dbd menuYesNo.dbd [nrahman@sunfire03]% java -jar /u/nrahman/EPICS/VDCT-Files/VisualDCT.jar softIoc.dbd Loading VisualDCT v2.6 build 1274... Directive to load DBD: 'softIoc.dbd'. No DBD loaded! Exiting... *********************************************************************************************** I checked to see if there were any accidental changes to the file but none observed using "ls -l" at the terminal (snipped screenshot): -r--r--r--+ 1 nrahman users 596 Aug 17 16:55 menuSimm.dbd -r--r--r--+ 1 nrahman users 605 Aug 17 16:55 menuYesNo.dbd -r--r--r--+ 1 nrahman users 1004 Aug 17 16:56 permissiveRecord.dbd -r--r--r--+ 1 nrahman users 2789 Aug 17 16:56 printfRecord.dbd -r--r--r--+ 1 nrahman users 6303 Aug 17 16:56 selRecord.dbd -r--r--r--+ 1 nrahman users 8880 Aug 17 16:56 seqRecord.dbd -r--r--r--+ 1 nrahman users 387832 Aug 17 16:56 softIoc.dbd -r--r--r--+ 1 nrahman users 753 Aug 17 16:56 stateRecord.dbd -r--r--r--+ 1 nrahman users 879 Aug 17 16:56 stdRecords.dbd -r--r--r--+ 1 nrahman users 1728 Aug 17 16:56 stringinRecord.dbd -r--r--r--+ 1 nrahman users 2116 Aug 17 16:56 stringoutRecord.dbd -r--r--r--+ 1 nrahman users 2051 Aug 17 16:56 subArrayRecord.dbd -r--r--r--+ 1 nrahman users 6326 Aug 17 16:56 subRecord.dbd -r--r--r--+ 1 nrahman users 99 Aug 17 16:55 system.dbd The only *.dbd files that I can open with VDCT for EPICS 3.15.5 are the following:
Once template is opened, I am unable to create any records given that "stdRecords.dbd" wasn't loaded and can't be loaded. Any other suggestions you might have for me? Thanks, Nab On Wed, Nov 29, 2017 at 3:44 PM, Andrew Johnson <[email protected]> wrote: Hi Nab,
ANJ, 21 Dec 2017 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
