Hello, I am currently using EPICS Base 3.15.5 with a linux x86_64 machine and am a relatively new user to EPICS. I would like to use VDCT to build EPICS databases for EPICS 3.15.5 (stable release) and noticed that VDCT will not load the base version "base.dbd" file found in the base directory. I have been able to successfully load VDCT with EPICS 3.14.12.6's "base.dbd" file but not with EPICS 3.15.5 I took a look at the contents of the .dbd files for both versions to compare and noticed they are almost the same except for the following:
I can load "devSoft.dbd" for EPICS 3.15.5 and VDCT will open and show a blank template but unable to add other dbd files. Has anyone in the EPICS community been able to successfully run VDCT with EPICS 3.15.5? Thanks for the help, Nab
ANJ, 21 Dec 2017 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
