Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: Re: time stamp on vxWorks jumping to the future
To: Dirk Zimoch <dirk.zimoch@psi.ch>
Cc: tech-talk@aps.anl.gov
Date: Mon, 27 Nov 2017 20:04:36 -0600
On 11/27/2017 02:47 AM, Dirk Zimoch wrote:
> On 24.11.2017 17:04, Michael Davidsaver wrote:
>> On 11/24/2017 01:50 AM, Dirk Zimoch wrote:
>>> On 20.11.2017 11:10, Dirk Zimoch wrote:
>>>> Hello everyone,
>>>> From time to time we see a strange problem with the timestamp on our
>>>> vxWorks 5.5 IOCs. The timestamp jumps to the future (e.g. 2071). I have
>>>> seen it happen on EPICS 3.14.12 as well as 3.14.8. Not all but more than
>>>> one IOC seem to be affected from such an incident. Not all jump to the
>>>> same future time.
>>>> Has anyone else seen this effect?
>>>> Can a corrupted NTP message cause this?
>>>> Dirk
>>> Example:
>>> ZPSAF15-VME > NTPTime_Report 1
>>> NTP driver is synchronized with server
>>> Syncronization interval = 60.0 seconds
>>> Last synchronized at 2017-11-24 08:45:29.149741
>>> OS tick rate = 100 Hz (nominal)
>>> Measured tick rate = 100.024 Hz
>>> NTP Server = 129.129.190.1
>>> value = 0 = 0x0
>>> ZPSAF15-VME > date
>>> 2073/05/20 11:20:31.396217
>>> value = 27 = 0x1b
>>> Time jumped this night, only on this IOC.
>> Are there other time providers in this IOC?  What does
>> "generalTimeReport 5" show?
> The system has been restarted meanwhile, but here is the report:
> ZPSAF15-VME > generalTimeReport 5
> Backwards time errors prevented 2169 times.
> Current Time Providers:
>     "NTP", priority = 100
>         Current Time is 2017-11-27 09:46:31.885855.
>     "OS Clock", priority = 999
>         Current Time is 2017-11-27 09:46:31.885192.
> Event Time Providers:
>         No Providers registered.
> value = 0 = 0x0
It seems odd to trip the backwards time detection with only one time provider.
Of course this may due to the local oscillator (decrementer) is running
slightly fast than 100Hz.
I saw something like this from an EVR where reading the current time occasionally
resulted in a vme bus error (a firmware issue long fixed).  As a result of this the
mrfioc2 time provider does some fairly strict tests to avoid returning a bad time to
generalTime.  If this sort of thing happens again, it might be worthwhile to add some
additional sanity checking to the NTP provider.
This depends on how much, if any, validation is done by sntpcTimeGet().
Re: time stamp on vxWorks jumping to the future Maren Purves
Re: time stamp on vxWorks jumping to the future Hartman, Steven M.
time stamp on vxWorks jumping to the future Dirk Zimoch
Re: time stamp on vxWorks jumping to the future Dirk Zimoch
Re: time stamp on vxWorks jumping to the future Michael Davidsaver
Prev: Driver for the SM300 john.holt
Next: Re: time stamp on vxWorks jumping to the future Maren Purves
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Prev: Re: time stamp on vxWorks jumping to the future Dirk Zimoch
ANJ, 28 Nov 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
