On Mon, Nov 20 2017, Wang Xiaoqiang <[email protected]> wrote:
> The UDF (UnDeFined) alarm and INVALID severity is to indicate the values
> are default values, have not got updated by the driver. This is the same
> behavior as the EPICS database gets initialized on start-up.
> Calling setParamStatus to clear the alarm status is all correct. It is
> then necessary to call driver.updatePVs() to inform ca clients with a
> DBE_ALARM event update. Otherwise this update event will be delayed
> until the next driver.updatePVs() call. And in PCASpy 0.6+, every caput
> triggers a call to driver.updatePVs(). That explains seeing all four
> updates together, in which channel A gives a value update and B,C,D give
> an alarm update.
> To conclude, it is an incompatible change introduced in PCASpy 0.6. I
> created an issue to track this.
> https://github.com/paulscherrerinstitute/pcaspy/issues/48
> In any case, it is best to explicitly call driver.updatePVs() after
> calling setParam, setParamStatus, setParamEnums, setParamInfo. I will
> add this the docs.
Thanks, Xiaoqiang. This is all very useful info, and adding it to the
documentation would be great. I'll add updatePVs() to my code where
needed.
jamie.
signature.asc
Description: PGP signature
- issue with either camonitor or pcaspy in 3.15? Jameson Graef Rollins
- Re: issue with either camonitor or pcaspy in 3.15? Wang Xiaoqiang
- Re: issue with either camonitor or pcaspy in 3.15? Jameson Graef Rollins
RE: Possible bug in areaDetector/ADSupport/supportApp/nexusSrc/Makefile? Mark Rivers
synApps_5_8 compilation error Mrinal Kanti Bera
<2017>
Anyone else using Bira Ethernet Power Supply Controllers? Dunning, Michael
<2017>
