Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: Re: Compile error with areaDetector
To: Mark Rivers <rivers@cars.uchicago.edu>
Cc: "tech-talk@aps.anl.gov" <tech-talk@aps.anl.gov>
Date: Wed, 15 Nov 2017 13:58:13 +0100
Hi Mark,
I'm using:
 $gcc --version
gcc (Ubuntu 4.8.4-2ubuntu1~14.04.3) 4.8.4
$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 14.04.5 LTS
Release:        14.04
Codename:       trusty
Jörn
> Hi Jörn,
> I don't have experience with gcc 5.4.0.  But you say you are also getting an
> error with gcc 4.8.  I am running gcc 4.8.5
> gcc (GCC) 4.8.5 20150623 (Red Hat 4.8.5-16)
> and ntndArrayConverter.cpp compiles fine for me with that compiler.  Exactly
> which version of gcc 4.8 is failing for you?
> Mark
> ________________________________
> From: tech-talk-bounces@aps.anl.gov <tech-talk-bounces@aps.anl.gov> on
> behalf of Dreyer, Dr. Joern <j.dreyer@hzdr.de> Sent: Wednesday, November
> 15, 2017 1:26 AM
> To: tech-talk@aps.anl.gov
> Subject: Compile error with areaDetector
> Hi,
> I have run into a problem with areaDetector compilation when enabling EPICS4
> using version 4.6.0 on Ubuntu16.04.3 LTS.
> ../ntndArrayConverter.cpp: In member function ‘void
> NTNDArrayConverter::fromUndefinedAttribute(epics::pvData::PVStructurePtr)’:
> ../ntndArrayConverter.cpp:497:54: error: no matching function for call to
> ‘std::tr1::shared_ptr<epics::pvData::PVField>::reset() const’
>    dest->getSubField<PVUnion>("value")->get().reset();
> In file included from /usr/include/c++/5/tr1/memory:50:0,
>    from
> /home/wuestenf/EPICS/EPICS-3.15.5/EPICS-CPP-4.6.0/pvDataCPP/include/pv/share
> dPtr.h:124, from
> /home/wuestenf/EPICS/EPICS-3.15.5/EPICS-CPP-4.6.0/pvDataCPP/include/pv/pvTyp
> e.h:41, from
> /home/wuestenf/EPICS/EPICS-3.15.5/EPICS-CPP-4.6.0/pvDataCPP/include/pv/pvDis
> play.h:14, from
> /home/wuestenf/EPICS/EPICS-3.15.5/EPICS-CPP-4.6.0/normativeTypesCPP/include/
> pv/ntndarray.h:17, from ../ntndArrayConverter.h:2,
>    from ../ntndArrayConverter.cpp:4:
> /usr/include/c++/5/tr1/shared_ptr.h:644:7: note: candidate: void
> std::tr1::__shared_ptr<_Tp, _Lp>::reset() [with _Tp =
> epics::pvData::PVField; __gnu_cxx::_Lock_policy _Lp =
> (__gnu_cxx::_Lock_policy)2u] <near match>
>    reset() // never throws
> /usr/include/c++/5/tr1/shared_ptr.h:644:7: note:  passing ‘const PVFieldPtr*
> {aka const std::tr1::shared_ptr<epics::pvData::PVField>*}’ as ‘this’
> argument discards qualifiers
> /usr/include/c++/5/tr1/shared_ptr.h:649:9: note: candidate: template<class
> _Tp1> void std::tr1::__shared_ptr<_Tp, _Lp>::reset(_Tp1*) [with _Tp1 = _Tp1;
> _Tp = epics::pvData::PVField; __gnu_cxx::_Lock_policy _Lp =
>    reset(_Tp1* __p) // _Tp1 must be complete.
> /usr/include/c++/5/tr1/shared_ptr.h:649:9: note:  template argument
> deduction/substitution failed:
> ../ntndArrayConverter.cpp:497:54: note:  candidate expects 1 argument, 0
> provided
>    from
> dPtr.h:124, from
> e.h:41, from
> play.h:14, from
> /usr/include/c++/5/tr1/shared_ptr.h:658:9: note: candidate: template<class
> _Tp1, class _Deleter> void std::tr1::__shared_ptr<_Tp, _Lp>::reset(_Tp1*,
> _Deleter) [with _Tp1 = _Tp1; _Deleter = _Deleter; _Tp =
>    reset(_Tp1* __p, _Deleter __d)
> /usr/include/c++/5/tr1/shared_ptr.h:658:9: note:  template argument
> ../ntndArrayConverter.cpp:497:54: note:  candidate expects 2 arguments, 0
> provided
> The used gcc version is 5.4.0. On Ubuntu 14.04.5 LTS The error comes at the
> same line, but different problem:
> ../ntndArrayConverter.cpp:497:54: error: passing ‘const PVFieldPtr {aka
> const std::tr1::shared_ptr<epics::pvData::PVField>}’ as ‘this’ argument of
> ‘void std::tr1::__shared_ptr<_Tp, _Lp>::reset() [with _Tp =
> (__gnu_cxx::_Lock_policy)2u]’ discards qualifiers [-fpermissive]
> here the used gcc version is 4.8. It look like an explicit typecast is
> necessary here. But what would be the correct type?
> Regards,
> Jörn
Re: Compile error with areaDetector Mark Rivers
Compile error with areaDetector Dreyer, Dr. Joern
Prev: Re: Problem when formating a field as HEX32 Mark Rivers
Next: Re: Problem when formating a field as HEX32 Pilar Gil Jaldo
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Prev: Re: Compile error with areaDetector Mark Rivers
Next: Re: Compile error with areaDetector Mark Rivers
ANJ, 15 Nov 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
