Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: Compile error with areaDetector
To: tech-talk@aps.anl.gov
Date: Wed, 15 Nov 2017 08:26:09 +0100
I have run into a problem with areaDetector compilation when enabling EPICS4 using version 4.6.0 on Ubuntu16.04.3 LTS.
../ntndArrayConverter.cpp: In member function ‘void NTNDArrayConverter::fromUndefinedAttribute(epics::pvData::PVStructurePtr)’: ../ntndArrayConverter.cpp:497:54: error: no matching function for call to ‘std::tr1::shared_ptr<epics::pvData::PVField>::reset() const’
  dest->getSubField<PVUnion>("value")->get().reset();
In file included from /usr/include/c++/5/tr1/memory:50:0,
from /home/wuestenf/EPICS/EPICS-3.15.5/EPICS-CPP-4.6.0/pvDataCPP/include/pv/sharedPtr.h:124, from /home/wuestenf/EPICS/EPICS-3.15.5/EPICS-CPP-4.6.0/pvDataCPP/include/pv/pvType.h:41, from /home/wuestenf/EPICS/EPICS-3.15.5/EPICS-CPP-4.6.0/pvDataCPP/include/pv/pvDisplay.h:14, from /home/wuestenf/EPICS/EPICS-3.15.5/EPICS-CPP-4.6.0/normativeTypesCPP/include/pv/ntndarray.h:17,
  from ../ntndArrayConverter.h:2,
  from ../ntndArrayConverter.cpp:4:
/usr/include/c++/5/tr1/shared_ptr.h:644:7: note: candidate: void std::tr1::__shared_ptr<_Tp, _Lp>::reset() [with _Tp = epics::pvData::PVField; __gnu_cxx::_Lock_policy _Lp = (__gnu_cxx::_Lock_policy)2u] <near match>
  reset() // never throws
/usr/include/c++/5/tr1/shared_ptr.h:644:7: note: passing ‘const PVFieldPtr* {aka const std::tr1::shared_ptr<epics::pvData::PVField>*}’ as ‘this’ argument discards qualifiers /usr/include/c++/5/tr1/shared_ptr.h:649:9: note: candidate: template<class _Tp1> void std::tr1::__shared_ptr<_Tp, _Lp>::reset(_Tp1*) [with _Tp1 = _Tp1; _Tp = epics::pvData::PVField; __gnu_cxx::_Lock_policy _Lp = (__gnu_cxx::_Lock_policy)2u]
  reset(_Tp1* __p) // _Tp1 must be complete.
/usr/include/c++/5/tr1/shared_ptr.h:649:9: note: template argument deduction/substitution failed: ../ntndArrayConverter.cpp:497:54: note: candidate expects 1 argument, 0 provided
/usr/include/c++/5/tr1/shared_ptr.h:658:9: note: candidate: template<class _Tp1, class _Deleter> void std::tr1::__shared_ptr<_Tp, _Lp>::reset(_Tp1*, _Deleter) [with _Tp1 = _Tp1; _Deleter = _Deleter; _Tp = epics::pvData::PVField; __gnu_cxx::_Lock_policy _Lp = (__gnu_cxx::_Lock_policy)2u]
  reset(_Tp1* __p, _Deleter __d)
/usr/include/c++/5/tr1/shared_ptr.h:658:9: note: template argument deduction/substitution failed: ../ntndArrayConverter.cpp:497:54: note: candidate expects 2 arguments, 0 provided
The used gcc version is 5.4.0. On Ubuntu 14.04.5 LTS The error comes at the same line, but different problem:
../ntndArrayConverter.cpp: In member function ‘void NTNDArrayConverter::fromUndefinedAttribute(epics::pvData::PVStructurePtr)’: ../ntndArrayConverter.cpp:497:54: error: passing ‘const PVFieldPtr {aka const std::tr1::shared_ptr<epics::pvData::PVField>}’ as ‘this’ argument of ‘void std::tr1::__shared_ptr<_Tp, _Lp>::reset() [with _Tp = epics::pvData::PVField; __gnu_cxx::_Lock_policy _Lp = (__gnu_cxx::_Lock_policy)2u]’ discards qualifiers [-fpermissive]
here the used gcc version is 4.8. It look like an explicit typecast is necessary here. But what would be the correct type?
Jörn
Re: Compile error with areaDetector Mark Rivers
Prev: Re: Building AreaDetector from source Lang, Keenan C.
Next: Re: Building AreaDetector from source Stephen Molloy
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Prev: Re: Building AreaDetector from source Stephen Molloy
Next: Re: Compile error with areaDetector Mark Rivers
ANJ, 15 Nov 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
