Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: Re: EPICS communication paradigm
To: renato sanhueza <renato.sanhueza@alumnos.usm.cl>
Cc: EPICS tech-talk <tech-talk@aps.anl.gov>
Date: Mon, 13 Nov 2017 12:32:35 -0500
Hi Renato,
In case it was not clear, in pvAccess, the RPC is provided in addition to the client/server calls.
Bob
On Mon, Nov 13, 2017 at 11:39 AM, renato sanhueza <renato.sanhueza@alumnos.usm.cl> wrote:
---------- Forwarded message ----------
From: renato sanhueza <renato.sanhueza@alumnos.usm.cl>
Date: Mon, Nov 13, 2017 at 1:39 PM
To: Ralph Lange <ralph.lange@gmx.de>
Hi Ralph,
Mi final conclusions make more sense now thanks to you.
As you say the EPICS/CA protocol appears to be an original thing and it is also old. We can easily classify it under the Client-Server Paradigm (Channel Access clients and Channel Access servers communicate) which is also an old an "general" paradigm and the base of many others.
This is further confirmed by the fact that EPICS V4 claims to provide a new protocol with RPC communication:
  • The Remote Procedure Call Paradigm has a lower level of abstraction than the Distributed Object Paradigm. Even tho it is feasible it makes little sense to me that a new version of any middleware will implement a  protocol with a lower level of abstraction.
  • In the other hand the Remote Procedure Call Paradigm provides a higher level of abstraction than the "raw" Client-Server Paradigm so it makes sense that EPICS V4 implemented RPC.
Thanks for your time. I hope this discussion also contributed with a little theoretical information for the community :)
On Mon, Nov 13, 2017 at 12:15 PM, Ralph Lange <ralph.lange@gmx.de> wrote:
Hi Renato,
One reason making it hard to decide which of the common communication paradigms EPICS/CA are based on: EPICS/CA have been designed in the 80s, i.e. years before Distributed Objects (and their communication paradigms) were developed.
If you look at currently commonly used protocols, CA shares a number of properties with OPC UA, in that it offers:
  • Discovery: work transparently across multiple servers on local PCs and/or networks
  • Global address space: all data is found through its unique name
  • On-demand: read and write data/information based on access-permissions
  • Subscriptions: monitor data/information when values change
Hope this helps,
~Ralph
On Sun, Nov 12, 2017 at 1:17 AM, renato sanhueza <renato.sanhueza@alumnos.usm.cl> wrote:
Hiding things is a common feature associated to a high level of abstraction. Thanks again for your time Mark. I will continue reflecting about this topic with the information you gave me.
On Sat, Nov 11, 2017 at 8:36 PM, Mark Rivers <rivers@cars.uchicago.edu> wrote:
I'm not a computer scientist by any means.  But I think it is fair to say that Channel Access operates at a fairly low level of abstraction.  It deliberately hides the "object" nature of EPICS records.  It only provides access to specific fields in those records.  So there is no capability of introspection of the record structure, etc.
There is a new EPICS protocol called pvAccess, commonly known as EPICS V4.  It provides a much higher level of abstraction, and is designed with middleware services as one of its target applications.  It allows the transmission of arbitrary structured data with full introspection.
Sent: Saturday, November 11, 2017 4:28 PM
To: Mark Rivers
Cc: tech-talk@aps.anl.gov
Hi Mark,
Thanks for your answer. You give a good summary of the whole communication process. I was asking about the communication paradigm as an attempt to determine in which level of abstraction EPICS works.
For example the Message Passing Paradigm is associated with the lowest level of abstraction in distributed inter-process communications. Message Systems Paradigm (aka Message Oriented Middleware) works in a higher level of abstraction than Message Passing, but lower than Distributed Object Paradigm.
EPICS use the Channel Access Protocol to communicate clients and servers, but I couldn't intuitively map this protocol to any of the "common" communication paradigms I know (besides the Distributed Objects Paradigm).
On Sat, Nov 11, 2017 at 6:59 PM, Mark Rivers <rivers@cars.uchicago.edu<mailto:rivers@cars.uchicago.edu>> wrote:
Hi Renato,
What you said is basically correct.   An EPICS control system typically consists of multiple channel access servers located on multiple computers.  There are also multiple channel access clients located on multiple computers.  The clients normally locate EPICS process variables (PVs) on the servers using a UDP broadcast with the PV name, and then connect to them with TCP.  They can then subscribe to callbacks from the servers whenever the PV changes (publish/subscribe model), and can write new values to the PVs.
I'm not sure if this answers your question?
From: tech-talk-bounces@aps.anl.gov<mailto:tech-talk-bounces@aps.anl.gov> <tech-talk-bounces@aps.anl.gov<mailto:tech-talk-bounces@aps.anl.gov>> on behalf of renato sanhueza <renato.sanhueza@alumnos.usm.cl<mailto:renato.sanhueza@alumnos.usm.cl>>
Sent: Saturday, November 11, 2017 1:05 PM
To: tech-talk@aps.anl.gov<mailto:tech-talk@aps.anl.gov>
Subject: EPICS communication paradigm
Hi, I am learning about EPICS and I think I understand the basic concepts about it but I am still unable to determine in which communication paradigm is EPICS based on.
My best guess is that EPICS implements the Distributed Object Paradigm because Records are object distributed across different Channel Access Servers. Other technologies which implement this paradigm are CORBA and JavaRMI for example.
I would really appreciate if someone can point me in the right direction.
Thanks in advance
Renato Sanhueza Ulsen
Ing Civil Informática.
EPICS communication paradigm renato sanhueza
Re: EPICS communication paradigm Mark Rivers
Re: EPICS communication paradigm renato sanhueza
Re: EPICS communication paradigm Ralph Lange
Fwd: EPICS communication paradigm renato sanhueza
Prev: Fwd: EPICS communication paradigm renato sanhueza
Next: Re: areaDetector and HDF5 file saving segafaults Hinko Kocevar
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Next: Problem when formating a field as HEX32 Pilar Gil Jaldo
ANJ, 14 Nov 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
