1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS communication paradigm
Date: Sat, 11 Nov 2017 19:28:10 -0300
Hi Mark,
Thanks for your answer. You give a good summary of the whole communication process. I was asking about the communication paradigm as an attempt to determine in which level of abstraction EPICS works.
For example the Message Passing Paradigm is associated with the lowest level of abstraction in distributed inter-process communications. Message Systems Paradigm (aka Message Oriented Middleware) works in a higher level of abstraction than Message Passing, but lower than Distributed Object Paradigm.
EPICS use the Channel Access Protocol to communicate clients and servers, but I couldn't intuitively map this protocol to any of the "common" communication paradigms I know (besides the Distributed Objects Paradigm).
On Sat, Nov 11, 2017 at 6:59 PM, Mark Rivers <[email protected]> wrote:
Hi Renato,
What you said is basically correct.   An EPICS control system typically consists of multiple channel access servers located on multiple computers.  There are also multiple channel access clients located on multiple computers.  The clients normally locate EPICS process variables (PVs) on the servers using a UDP broadcast with the PV name, and then connect to them with TCP.  They can then subscribe to callbacks from the servers whenever the PV changes (publish/subscribe model), and can write new values to the PVs.
I'm not sure if this answers your question?
From: [email protected] <[email protected]> on behalf of renato sanhueza <[email protected].cl>
Sent: Saturday, November 11, 2017 1:05 PM
To: [email protected]
Subject: EPICS communication paradigm
Hi, I am learning about EPICS and I think I understand the basic concepts about it but I am still unable to determine in which communication paradigm is EPICS based on.
My best guess is that EPICS implements the Distributed Object Paradigm because Records are object distributed across different Channel Access Servers. Other technologies which implement this paradigm are CORBA and JavaRMI for example.
I would really appreciate if someone can point me in the right direction.
Thanks in advance
Renato Sanhueza Ulsen
Ing Civil Informática.
Re: EPICS communication paradigm Mark Rivers
EPICS communication paradigm renato sanhueza
Prev: Re: EPICS communication paradigm Mark Rivers
Next: Re: EPICS communication paradigm Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
