1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS base R3.15.5 special CONFIG and RULE files
To: "'[email protected]'" <[email protected]>
Date: Fri, 10 Nov 2017 13:38:26 +0100
[sorry for possible duplicates, forgot to reply to the list]
On 11/09/2017 11:59 PM, Luchini, Kristi L. wrote:
> However, my RULES file from R3.14.12, now either generate errors
> during the build or it will generate an empty alhConfig which it
> installs in to $TOP/alh.
> Is there an example of a RULES_<file type> that I can used. Below is
> what I am using, which clearly is wrong.
> File configure/Makefile
> CHECK_RELEASE = YES
> TARGETS = $(CONFIG_TARGETS)
> CONFIGS += $(subst ../,,$(wildcard $(CONFIG_INSTALLS)))
> CFG +=CONFIG_ALARMS RULES_ALARMS
> CFG +=CONFIG_PROTOS
> include $(TOP)/configure/RULES
> File: configure/CONFIG_ALARMS
> FILE_TYPE+=ALHS
> INSTALL_ALHS = $(INSTALL_LOCATION)/alh
This is no longer needed as there are now a similar definitions in base,
which use ALH, not ALHS. You can keep you won FILE_TYPE, though, since
due to the different name there is no conflict.
> File:  configure/RULES_ALARMS    --- similar to R3.14.12   RULES.Db
This is a mistake. RULES.Db is an overly complicated monster. I wish
there was a way to completely disable it.
All you need is the vpaths:
> vpath %.alhConfig $(USR_VPATH) $(GENERIC_SRC_DIRS) $(dir $(ALH))
> vpath %.alhsubstitutions $(USR_VPATH) $(GENERIC_SRC_DIRS) $(COMMON_DIR)
however, these are not good. I would rather use
vpath %.alhConfig $(USR_VPATH) $(GENERIC_SRC_DIRS) $(COMMON_DIR)
(Presumably alhsubstitutions are sources, while alhConfig may be sources
or produced by the rule below.)
The only rule you need is
> $(COMMON_DIR)/%.alhConfig: %.alhsubstitutions
>         @echo "Inflating alhConfig from $< using local rule"
>         @$(RM) $@
>         @echo "$(MSI) -S$< > $(@F) </dev/null"
>         @$(MSI) -I.. $(ALHFLAGS) -S$< </dev/null > $@
which I would re-write as
	$(ECHO) "Inflating alhConfig from $< using local rule"
	$(MSI) -I.. $(ALHFLAGS) -S$< > [email protected]
	$(MV) [email protected] $@
(Why suppress echoing of the command line and then echo manually in a
separate command, just so you don't see the $(ALHFLAGS) parameter? The
"output to .tmp, then mv" pattern is to make parallel make more reliable.)
Also, the include of RULES_ALARMS below
> File:  Makefile:
> TOP=../../..
> include $(TOP)/configure/CONFIG
> ALHS += ntwk_inj.alhConfig
> include $(TOP)/configure/RULES_ALARMS
is automatically done by the base rules.
Cheers
Ben
"Make it so they have to reboot after every typo." ― Scott Adams
Attachment: signature.asc
Description: OpenPGP digital signature
Re: EPICS base R3.15.5 special CONFIG and RULE files Bruce Hill
RE: EPICS base R3.15.5 special CONFIG and RULE files Luchini, Kristi L.
Prev: Re: EPICS base R3.15.5 special CONFIG and RULE files Andrew Johnson
Next: Re: EPICS base R3.15.5 special CONFIG and RULE files Bruce Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
