Hi Andrew,
>Did you mean to send this message to tech-talk, because I don't think anyone outside of SLAC can help you with what I presume to be a local feature of your installation.
>The "-1.0" on the end of your Base version number is another indicator that you have local customizations which the rest of us probably won't know anything about.
I was thinking to myself that I should remove the 1-0 in the EPICS base, but apparently my fingers were working independently! The EPICS Base version I am referring to is the downloaded version of R3.15.5.
In an attempt to clarify, I have an "alhsubstitutions" file (see below), from which I want to generate an "alhConfig" file and install into $TOP/alh
Under EPICS R3.14.12, I created a RULES.Alarms, similar to RULES.Db, which uses MSI to generate a db file from a substitutions file. If I look at the R3.15.5 Applications Developer Guide, sections 4.6.34 and 4.6.35, it does talk about CONFIG_<file type> and RULES_<file type>. These files should be added to configure/Makefile.
However, my RULES file from R3.14.12, now either generate errors during the build or it will generate an empty alhConfig which it installs in to $TOP/alh.
Is there an example of a RULES_<file type> that I can used. Below is what I am using, which clearly is wrong.
File configure/Makefile
CHECK_RELEASE = YES
TARGETS = $(CONFIG_TARGETS)
CONFIGS += $(subst ../,,$(wildcard $(CONFIG_INSTALLS)))
CFG +=CONFIG_ALARMS RULES_ALARMS
CFG +=CONFIG_PROTOS
include $(TOP)/configure/RULES
File: configure/CONFIG_ALARMS
FILE_TYPE+=ALHS
INSTALL_ALHS = $(INSTALL_LOCATION)/alh
File: configure/RULES_ALARMS --- similar to R3.14.12 RULES.Db
[luchini@lcls-dev3 configure]$ cat RULES_ALARMS
# Where to install configuration files for ALH (Alarm Handler)
vpath %.alhConfig $(USR_VPATH) $(GENERIC_SRC_DIRS) $(dir $(ALH))
vpath %.alhsubstitutions $(USR_VPATH) $(GENERIC_SRC_DIRS) $(COMMON_DIR)
INSTALL_ALH = $(INSTALL_LOCATION)/alh
##################################################### Restore Flags
INSTALL_ALHFLAGS = -I $(INSTALL_ALH)
RELEASE_ALHFLAGS = $(patsubst %/dbd,%/restore, $(RELEASE_DBDFLAGS))
ALHFLAGS = $($*_ALHFLAGS) $(USR_ALHFLAGS) -I. $(GENERIC_SRC_INCLUDES) $(INSTALL_ALHFLAGS) $(RELEASE_ALHFLAGS)
ALHFLAGS += -I$(COMMON_DIR)
##################################################### Targets
INSTALL_ALHS += $(addprefix $(INSTALL_ALH)/,$(notdir $(ALHS)))
COMMON_ALHS += $(filter $(COMMON_DIR)/%, $(foreach file, $(ALHS), \
$(firstword $(SOURCE_ALHS) $(COMMON_DIR)/$(file) ) ) )
SOURCE_ALHS = $(wildcard $(file) $(SOURCE_ALHS_bbb) )
SOURCE_ALHS_bbb = $(foreach dir, $(GENERIC_SRC_DIRS), $(SOURCE_ALHS_aaa) )
SOURCE_ALHS_aaa = $(addsuffix /$(file), $(dir) )
COMMONS = $(COMMON_DIR)/*.alhConfig \
$(COMMON_DIR)/*.alhsubstitutions
ifndef T_A
COMMON_DIR = .
INSTALL_ALHS =
COMMON_ALHS = .
COMMONS = $(ALHS)
-include $(TOP)/configure/O.$(EPICS_HOST_ARCH)/CONFIG_APP_INCLUDE
all: install
install: buildInstall
buildInstall : build
rebuild: clean install
.PHONY: all inc build install clean rebuild buildInstall
endif # T_A defined
ifneq (,$(strip $(ALH_INSTALLS)))
buildInstall : restoreInstalls
endif
.PHONY: restoreInstalls
build : $(COMMON_ALHS) \
$(INSTALL_ALHS)
#clean::
clean:
@$(RM) $(COMMONS)
##################################################### Substitution files
$(INSTALL_ALH)/%.alhsubstitutions: %.alhsubstitutions
@echo "Installing alhsubstitutions file $@"
@$(INSTALL) -d -m 644 $< $(@D)
.PRECIOUS: $(COMMON_DIR)/%.alhsubstitutions
##################################################### alhConfig files
$(COMMON_DIR)/%.alhConfig: %.alhsubstitutions
@echo "Inflating alhConfig from $< using local rule"
@$(RM) $@
@echo "$(MSI) -S$< > $(@F) </dev/null"
@$(MSI) -I.. $(ALHFLAGS) -S$< </dev/null > $@
$(INSTALL_ALH)/%.alhConfig: $(COMMON_DIR)/%.alhConfig
@echo "Installing alhConfig file $@"
$(INSTALL_ALH)/%: %
@echo "Installing restore file $@"
$(INSTALL_ALH)/%: ../%
restoreInstalls: $(ALH_INSTALLS)
@echo "Installing $(^F)"
@$(INSTALL) -d -m 555 $^ $(INSTALL_ALH)
.PRECIOUS: $(COMMON_ALHS)
##################################################### END OF FILE
File: Makefile:
TOP=../../..
include $(TOP)/configure/CONFIG
ALHS += ntwk_inj.alhConfig
include $(TOP)/configure/RULES_ALARMS
File: ntwk_inj.alhsubstititons:
file ../../common/deviceTop.alhConfig
pattern { parent, grp, alias, guidance }
{ NULL, NTWK:INJ:1, Injector, "Injector network status" } }
- Kristi
-----Original Message-----
Sent: Thursday, November 09, 2017 1:33 PM
To: Luchini, Kristi L.; '[email protected]'
Subject: Re: EPICS base R3.15.5-1.0 special CONFIG and RULE files
Hi Kristi,
On 11/09/2017 01:26 PM, Luchini, Kristi L. wrote:
> I'm upgrading an EPICS IOC Application from R3.14.12 to R3.15.5-1.0
> and I'm using the new schema of adding configure/CONFIG_ALARMS file
> and including this file in the configure/Makefile. This does indeed
> install alhConfig files into the directory $TOP/alh. However, it
> method does not generate alhConfig files from an alhsubstitutions
> file, without adding configure/RULES.Alarms file. I was told that
> I don't need a special RULES file anymore with this new version of
> EPICS. Am I missing something?
Did you mean to send this message to tech-talk, because I don't think anyone outside of SLAC can help you with what I presume to be a local feature of your installation. The "-1.0" on the end of your Base version number is another indicator that you have local customizations which the rest of us probably won't know anything about.
- Andrew
Arguing for surveillance because you have nothing to hide is no different than making the claim, "I don't care about freedom of speech because I have nothing to say." -- Edward Snowdon
- Re: EPICS base R3.15.5 special CONFIG and RULE files Andrew Johnson
- Re: EPICS base R3.15.5 special CONFIG and RULE files Benjamin Franksen
RE: How to turn off spewing messaging from asyn/stream devicse. Mark Rivers
RE: How to turn off spewing messaging from asyn/stream devicse. Luchini, Kristi L.
<2017>
<2017>
