1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS base R3.15.5-1.0 special CONFIG and RULE files
To: "Luchini, Kristi L." <[email protected]>, "'[email protected]'" <[email protected]>
Date: Thu, 9 Nov 2017 15:32:50 -0600
Hi Kristi,
On 11/09/2017 01:26 PM, Luchini, Kristi L. wrote:
> I'm upgrading an EPICS IOC Application from R3.14.12 to R3.15.5-1.0
> and I'm using the new schema of adding  configure/CONFIG_ALARMS file
> and including this file in the configure/Makefile.  This does indeed
> install alhConfig files into the directory $TOP/alh. However, it
> method does not generate alhConfig files from an alhsubstitutions
> file, without  adding configure/RULES.Alarms file.   I was told that
> I don't need a special RULES file anymore with this new version of
> EPICS.  Am I missing something?
Did you mean to send this message to tech-talk, because I don't think
anyone outside of SLAC can help you with what I presume to be a local
feature of your installation. The "-1.0" on the end of your Base version
number is another indicator that you have local customizations which the
rest of us probably won't know anything about.
- Andrew
EPICS base R3.15.5-1.0 special CONFIG and RULE files Luchini, Kristi L.
Prev: How to turn off spewing messaging from asyn/stream devicse. Luchini, Kristi L.
Next: RE: How to turn off spewing messaging from asyn/stream devicse. Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: EPICS base R3.15.5-1.0 special CONFIG and RULE files Luchini, Kristi L.
Next: How to turn off spewing messaging from asyn/stream devicse. Luchini, Kristi L.
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
