Hi Mark,
Image size is 1936 x 1216, data type is uint16 (~2.3MB). Camera is AlliedVision Manta G-235B, controlled with aravis+aravisGigE. I'm saving some attributes - see the attached XML file. I'm using Single saving mode, saving one image per acquisition at ~10 images per second. It happens quite often, if I leave if running for couple of minutes I get the segfault. I have not yet tried reproducing with simDetector - will do. I'm using HDF5 ver 1.10.1 that comes with ADSupport. The thing is that I have not noticed this problems before, this now happens on a remote machine at an experiment we are conducting. It could be the hardware.. Thank you, Hinko On Tue, Nov 7, 2017 at 2:59 PM, Mark Rivers <[email protected]> wrote: Hi Hinko, .. the more I see the less I believe.., AE AoR
<?xml version="1.0" standalone="no" ?> <!-- Attributes --> <Attributes xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="NDAttributes.xsd" > <Attribute name="CameraManufacturer" type="EPICS_PV" source="CAM1:det1:Manufacturer_RBV" dbrtype="DBR_NATIVE" description="Camera manufacturer"/> <Attribute name="CameraModel" type="EPICS_PV" source="CAM1:det1:Model_RBV" dbrtype="DBR_NATIVE" description="Camera model"/> <Attribute name="ImageCounter" type="EPICS_PV" source="CAM1:det1:ArrayCounter_RBV" dbrtype="DBR_NATIVE" description="Array counter"/> <Attribute name="MaxSizeX" type="EPICS_PV" source="CAM1:det1:MaxSizeX_RBV" dbrtype="DBR_NATIVE" description="Detector X size"/> <Attribute name="MaxSizeY" type="EPICS_PV" source="CAM1:det1:MaxSizeY_RBV" dbrtype="DBR_NATIVE" description="Detector Y size"/> <Attribute name="BinX" type="EPICS_PV" source="CAM1:det1:BinX_RBV" dbrtype="DBR_NATIVE" description="Binning in X"/> <Attribute name="BinY" type="EPICS_PV" source="CAM1:det1:BinY_RBV" dbrtype="DBR_NATIVE" description="Binning in Y"/> <Attribute name="AcquireTimePV" type="EPICS_PV" source="CAM1:det1:AcquireTime_RBV" dbrtype="DBR_NATIVE" description="Camera acquire time"/> <Attribute name="AcquirePeriod" type="EPICS_PV" source="CAM1:det1:AcquirePeriod_RBV" dbrtype="DBR_NATIVE" description="Acquire period"/> <Attribute name="ImageMode" type="EPICS_PV" source="CAM1:det1:ImageMode_RBV" dbrtype="DBR_NATIVE" description="Image mode"/> <Attribute name="TriggerMode" type="EPICS_PV" source="CAM1:det1:TriggerMode_RBV" dbrtype="DBR_NATIVE" description="Trigger mode"/> <Attribute name="DeviceTemperature" type="EPICS_PV" source="CAM1:det1:DeviceTemperatu0_RBV" dbrtype="DBR_NATIVE" description="Device temperature"/> <Attribute name="Gain" type="EPICS_PV" source="CAM1:det1:Gain_RBV" dbrtype="DBR_NATIVE" description="Gain"/> <Attribute name="Current" type="EPICS_PV" source="DTU:Current" dbrtype="DBR_NATIVE" description="Current"/> <Attribute name="Temperature" type="EPICS_PV" source="DTU:Temperature" dbrtype="DBR_NATIVE" description="Temperature"/> <Attribute name="GaussParam1" type="EPICS_PV" source="DTU:GaussParam1" dbrtype="DBR_NATIVE" description="Gauss param 1"/> <Attribute name="GaussParam2" type="EPICS_PV" source="DTU:GaussParam2" dbrtype="DBR_NATIVE" description="Gauss param 2"/> <Attribute name="GaussParam3" type="EPICS_PV" source="DTU:GaussParam3" dbrtype="DBR_NATIVE" description="Gauss param 3"/> <Attribute name="GaussParam4" type="EPICS_PV" source="DTU:GaussParam4" dbrtype="DBR_NATIVE" description="Gauss param 4"/> <Attribute name="GaussParam5" type="EPICS_PV" source="DTU:GaussParam5" dbrtype="DBR_NATIVE" description="Gauss param 5"/> <Attribute name="GaussParam6" type="EPICS_PV" source="DTU:GaussParam6" dbrtype="DBR_NATIVE" description="Gauss param 6"/> <Attribute name="GaussParam7" type="EPICS_PV" source="DTU:GaussParam7" dbrtype="DBR_NATIVE" description="Gauss param 7"/> <Attribute name="GaussParam8" type="EPICS_PV" source="DTU:GaussParam8" dbrtype="DBR_NATIVE" description="Gauss param 8"/> <Attribute name="GaussParam9" type="EPICS_PV" source="DTU:GaussParam9" dbrtype="DBR_NATIVE" description="Gauss param 9"/> <Attribute name="GaussParam10" type="EPICS_PV" source="DTU:GaussParam10" dbrtype="DBR_NATIVE" description="Gauss param 10"/> <Attribute name="Sample" type="EPICS_PV" source="DTU:Sample" dbrtype="DBR_STRING" description="Sample"/> <Attribute name="Comment" type="EPICS_PV" source="DTU:Comment" dbrtype="DBR_STRING" description="Comment"/> <!-- <Attribute name="ID_Energy" type="EPICS_PV" source="ID34:Energy" dbrtype="DBR_NATIVE" description="Undulator energy"/> <Attribute name="AttributesFileParam" type="PARAM" source="ND_ATTRIBUTES_FILE" datatype="STRING" description="Attributes file param"/> --> </Attributes>
ANJ, 21 Dec 2017 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
