1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: RE: motor module compile problems
To: 'Jörn Dreyer' <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 8 Nov 2017 14:33:55 +0000
All of this code is C++.  In general it is recommended not to use NULL at all in C++, use 0 instead.  So I would suggest changing "(char) NULL" to "0".
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Jörn Dreyer
Sent: Wednesday, November 08, 2017 8:13 AM
To: [email protected]
Subject: motor module compile problems
I have had some trouble compiling the motor module (from git) on a openSuSE
Tumbleweed system with gcc 7.2.1. It fails in all motor drivers at the calls
of send_message where the last parameter is passed as (char) NULL. But in the
definition of send_message the last parameter is defined as char*.
What would be the correct fix for this? One could
1. modify all calls to send_message(..,..,(char) NULL) to
send_message(..,..,(char*) NULL), or
2. modify the definition of send_message(..,..,char*)to
send_message(..,..,char), but then other calls may fail.
I chose  the first solution to get it compiled.  If needed I can send a patch
file to correct all necessary lines.
Jörn
Re: motor module compile problems Andrew Johnson
motor module compile problems Jörn Dreyer
Prev: motor module compile problems Jörn Dreyer
Next: RE: caLab and real time os Mazanec Tomáš
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Next: Re: motor module compile problems Andrew Johnson
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
