1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: caLab and real time os
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 8 Nov 2017 13:13:18 +0000
Hi Pierrick,
we have a LabVIEW based sub-system (running NI real time OS, like you) using "official" NI EPICS support described here:
http://www.ni.com/white-paper/14144/en/
The drawback is that the published PV are missing some properties (e.g. EGU). We solved the issue by adding a softIoc with a DB with a fully qualified PV populated by the value retrieved by the LabVIEW PV using this pattern (and the other way round):
As suggested by Mark Rivers in this thread:
http://www.aps.anl.gov/epics/tech-talk/2016/msg01926.php
Luca
On Wed, 2017-11-08 at 07:03 +0000, Pierrick Hanlet wrote:
Thank you Carsten,
Can you recommend some options?
Best wishes,
Pierrick
On 11/08/2017 05:53 AM, Carsten Winkler wrote:
Hello Pierrick,
your LabVIEW expert is right. CaLab has native libraries which are not suitable for real time OS.
Best regards
Carsten Winkler (developer of CaLab)
Pierrick Hanlet <pierrick.hanlet@tokamakenergy.co.uk> schrieb am 07.11.2017:
Dear tech-talk,
Can someone clarify if there is a caLab library that can be used to build a labview vi
for a real time OS?  My labview expert has read somewhere that caLab is not
compatible.
Thank you,
Pierrick
-- Diese Nachricht wurde mit K-@ Mail gesendet.
Aufsichtsrat: Vorsitzender Dr. Karl Eugen Huthmacher, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Bernd Rech (kommissarisch), Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
<< Le informazioni contenute in questo messaggio di posta elettronica e relativi allegati sono riservate e confidenziali e ne è vietata la diffusione in qualunque modo eseguita. Qualora Lei non fosse la persona a cui il presente messaggio è destinato, La invitiamo ad eliminarlo e a darcene gentile comunicazione. Quanto precede ai fini del rispetto delle Legge 675/96 e del Decreto Legislativo 30/06/2003 n.196, sulla tutela dei dati personali >>
<< This e-mail is confidential and may well also be legally privileged. If you have received it in error, you are on notice of its status. Please notify us immediately by reply e-mail and then delete this message from your system. Please do not copy it or use it for any purposes, or disclose its contents to any other person: to do so could be a breach of confidence. Thank you for your co-operation. Please contact our IT Helpdesk on +3902380481 or email [email protected] if you need assistance >>
caLab and real time os Pierrick Hanlet
Re: caLab and real time os Carsten Winkler
Re: caLab and real time os Pierrick Hanlet
Prev: RE: caLab and real time os freddie.akeroyd
Next: motor module compile problems Jörn Dreyer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Next: RE: caLab and real time os Baily, Scott A
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
