During the build process certain directory paths are built into the
libraries and executables. As you are cross-comiling, these are paths
on the build computer. Your target computer has different paths.
On the target, try setting the following in your shell
> export PATH=$PATH:$HOME/base/bin/linux-arm
> export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$HOME/base/lib/linux-arm
If you're curious, you can use the 'readelf' or 'ldd' utilities to see
which library names and paths are built into an executable or library.
> $ x86_64-linux-gnu-readelf -d bin/linux-x86_64/caget
> Dynamic section at offset 0x6d90 contains 32 entries:
> Tag Type Name/Value
> 0x0000000000000001 (NEEDED) Shared library: [libca.so.3.16.1]
> 0x0000000000000001 (NEEDED) Shared library: [libCom.so.3.16.1]
> 0x0000000000000001 (NEEDED) Shared library: [libstdc++.so.6]
> 0x0000000000000001 (NEEDED) Shared library: [libm.so.6]
> 0x0000000000000001 (NEEDED) Shared library: [libgcc_s.so.1]
> 0x0000000000000001 (NEEDED) Shared library: [libc.so.6]
> 0x000000000000001d (RUNPATH) Library runpath: [/home/mdavidsaver/work/epics/base-git/lib/linux-x86_64]
> 0x000000000000000c (INIT) 0x1718
- A Problem : run it on the target board. 윤대희
Re: A Problem : run it on the target board. Seung-hee Nam
areaDetector and HDF5 file saving segafaults Hinko Kocevar
<2017>
<2017>
