Thanks to you, I solved the problem with cross-compile.
So, I moved it from Host os to taget board.
Because it has already been cross-compied.
And then
I tried to run the cross-compiled epics base on the target board.
root@plnx_arm:~/base/bin/linux-arm# ./softIoc
./softIoc: error while loading shared libraries: libdbRecStd.so: cannot open shared object file: No such file or directory
root@plnx_arm:~/base/bin/linux-x86_64# ./makeBaseApp.pl
Can't find EPICS base
But It failed.
Are there package files to add to the target board?
(I already put in besy-box, make, perl)
Should I do it differently?
I don’t know.
Thank you,
Dae Hee, Yoon
