Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: Re: concurrent put callbacks
To: "Mooney, Tim M." <mooney@aps.anl.gov>
Cc: "tech-talk@aps.anl.gov list" <tech-talk@aps.anl.gov>
Date: Thu, 2 Nov 2017 15:01:25 +0000
Several record types also support a DTYP of "Async Soft Channel” which can also be used for CA put callback. So you could have a dfanout or seq record, with PP output links, process a set of records that all have DTYP="Async Soft Channel”.
Although, the sseq tends to be my go-to record for this type of application.
Cheers,
Matt
> On Nov 2, 2017, at 9:43 AM, Mooney, Tim M. <mooney@aps.anl.gov> wrote:
> The sseq record can do up to 10 actions in parallel, and then wait for all of them to complete.  Any set of consecutive output links can be done in parallel, and then waited for before going on to the next link.  The WAITn fields control this.  For example, to execute LNK2 and LNK3 in parallel, set WAIT2 to "After 3", and set WAIT3 to "Wait"
> Tim Mooney (mooney@aps.anl.gov) (630)252-5417
> Beamline Controls Group (www.aps.anl.gov)
> Advanced Photon Source, Argonne National Lab
> From: tech-talk-bounces@aps.anl.gov <tech-talk-bounces@aps.anl.gov> on behalf of Andrew C. Starritt <Andrew.Starritt@synchrotron.org.au>
> Sent: Thursday, November 2, 2017 2:24:23 AM
> To: tech-talk@aps.anl.gov
> Subject: concurrent put callbacks
> Hi al,
> The sseq record is great for doing a number of sequential actions that require a CA put callback before going on to the next step.
> Is there an easy/recommended way a number of actions to run in parallel and then wait for all the CA put callbacks?
> Andrew C. Starritt | Principal Controls Engineer | Australian Synchrotron
> p: (03) 8540 4164 | f: (03) 8540 4200
> andrew.starritt@synchrotron.org.au | www.synchrotron.org.au
> 800 Blackburn Road, Clayton, Victoria 3168
concurrent put callbacks Andrew C. Starritt
Re: concurrent put callbacks Mooney, Tim M.
Prev: Re: concurrent put callbacks Mooney, Tim M.
Next: issue with either camonitor or pcaspy in 3.15? Jameson Graef Rollins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Next: RE: concurrent put callbacks Andrew C. Starritt
ANJ, 02 Nov 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
