It seems that your definition of GNU_DIR is not correct. The EPICS
build system searches for the cross-compiler in
${GNU_DIR}/bin/${GNU_TARGET}-gcc , etc.
In my case (I'm using Xilinx SDK 2013.4) it should be
GNU_DIR = /opt/Xilinx/SDK/2013.4/gnu/arm/lin
Hope this helps.
Shuei YAMADA
2017-11-01 16:48 GMT+09:00 윤대희 <[email protected]>:
> Hi.
> I am attempting to build EPICS into Zedboard.
> So I go through Tech-talk Messages.
> I discover this recipe.
> http://www.aps.anl.gov/epics/tech-talk/2016/msg00629.php
> I attempt to cross-compile
> First > gedit ~/.bashrc > export EPICS_BASE=/home/xilinx/epics/base
> export EPICS_HOST_ARCH=linux-x86_64
> export LANG=C
> second > base.x.x.x/configure/CONFIG_SITE > CROSS_COMPILER_TARGET_ARCHS =
> linux-arm
> CROSS_COMPILER_HOST_ARCHS=linux-x86_64
> Third > base.x.x.x/configure/os/CONFIG_SITE.Common.linux-x86_64 >
> #COMMANDLINE_LIBRARY = READLINE
> Fourth > base.x.x.x/configure/os/CONFIG_SITE.linux-x86_64.linux-arm >
> GNU_DIR = /usr
> GNU_TARGET = arm-linux-gnueabi
> Fifth > apt-get install libreadline6 libreadline6-dev gcc-arm-linux-gnueabi
> Sixth > make
> But It stops asLib.o
> Error below.
> clude/compiler/gcc -I../../../include/os/Linux -I../../../include
> -I/usr/local/vw/zynq-2011.09/arm-xilinx-linux-gnueabi/include -c asLib.c
> make[3]: /usr/local/vw/zynq-2011.09/bin/arm-xilinx-linux-gnueabi-gcc:
> Command not found
> ../../../configure/RULES_BUILD:229: recipe for target 'asLib.o' failed
> make[3]: *** [asLib.o] Error 127
> make[3]: Leaving directory '/home/xilinx/epics/base/src/libCom/O.linux-arm'
> ../../configure/RULES_ARCHS:58: recipe for target 'install.linux-arm' failed
> make[2]: *** [install.linux-arm] Error 2
> make[2]: Leaving directory '/home/xilinx/epics/base/src/libCom'
> ../configure/RULES_DIRS:84: recipe for target 'libCom.install' failed
> make[1]: *** [libCom.install] Error 2
> make[1]: Leaving directory '/home/xilinx/epics/base/src'
> configure/RULES_DIRS:84: recipe for target 'src.install' failed
> make: *** [src.install] Error 2
> I do not understand where this route came from
> “/usr/local/vw/zynq-2011.09/bin/arm-xilinx-linux-gnueabi-gcc”.
> How can I build successfully?
> Thank you.
> Dae Hee, Yoon
${GNU_DIR}/bin/${GNU_TARGET}-gcc and/or
Shuei Yamada,
High Energy Accelerator Research Organization (KEK)
mailto:[email protected]
- Crosscompiling EPICS for ARM Arch - zedboard : Error 윤대희
Re: concurrent put callbacks Mark Rivers
Re: concurrent put callbacks Mooney, Tim M.
<2017>
Data Conversion from CSS RDB Archiver to Archiver Appliance Abdalla Ahmad
<2017>
