Zhefu,
as Kay pointed out, the documentation describes some common use-cases for PVs in scripts. If the PV approach works for you, however, you might consider implementing the desired logic in your IOC instead. It is easily done on database level (e.g. with calc record). In this case you won't have to deal with OPI scripts. Anton. On Mon, Oct 30, 2017 at 8:49 AM, Kasemir, Kay <[email protected]> wrote:
ANJ, 21 Dec 2017 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
