I'm trying to have two AD based drivers and one streamdevice based driver included in one IOC. If I compile individual IOCs then things go fine. While building composite IOC, I get stuck in specifying DBD files in the Makefile which seems to fail. This is with EPICS base 3.15.4. The thing is if I do not call include $(ADCORE)/ADApp/commonDriverMakefile then the compile part goes fine, but of course I'm left with no AD DBDs/libs included in the IOC. Makefile: TOP=../.. include $(TOP)/configure/CONFIG #---------------------------------------- # ADD MACRO DEFINITIONS AFTER THIS LINE PROD_NAME = imgApp PROD_IOC += $(PROD_NAME) # <name>.dbd will be created from <name>Include.dbd DBD += $(PROD_NAME).dbd $(PROD_NAME)_DBD += aravisCameraSupport.dbd $(PROD_NAME)_DBD += tlccsSupport.dbd $(PROD_NAME)_DBD += tlpm100Support.dbd $(PROD_NAME)_DBD += drvAsynUSBTMC.dbd $(PROD_NAME)_DBD += base.dbd $(PROD_NAME)_DBD += stream.dbd $(PROD_NAME)_DBD += asyn.dbd # <name>_registerRecordDeviceDriver.cpp will be created from <name>.dbd PROD_SRCS += $(PROD_NAME)_registerRecordDeviceDriver.cpp $(PROD_NAME)Main.cpp # Add locally compiled object code PROD_LIBS += aravisCamera PROD_LIBS += tlccs PROD_LIBS += asyn PROD_LIBS += stream PROD_SYS_LIBS += aravis-0.4 PROD_SYS_LIBS += giomm-2.4 PROD_SYS_LIBS += usb-1.0 include $(ADCORE)/ADApp/commonDriverMakefile #============================= include $(TOP)/configure/RULES #---------------------------------------- # ADD RULES AFTER THIS LINE Failed compile messages: [...] make[3]: Entering directory '/home/hinkokocevar/git/ng3e-devel/stage/R3.15.4/iocs/imgioc-master+2/imgApp/src/O.linux-x86_64' Creating dbd file imgApp.dbd perl -CSD /home/hinkokocevar/git/ng3e-devel/root/R3.15.4/base/bin/linux-x86_64/dbdExpand.pl -I. -I.. -I../O.Common -I../../../dbd -I/home/hinkokocevar/git/ng3e-devel/root/R3.15.4/modules/adaravis-ESS-master+2/dbd -I/home/hinkokocevar/git/ng3e-devel/root/R3.15.4/modules/adcore-ESS-R3-1+1/dbd -I/home/hinkokocevar/git/ng3e-devel/root/R3.15.4/modules/adtlccs-master+1/dbd -I/home/hinkokocevar/git/ng3e-devel/root/R3.15.4/modules/asyn-ESS-R4-32+1/dbd -I/home/hinkokocevar/git/ng3e-devel/root/R3.15.4/modules/autosave-R5-8/dbd -I/home/hinkokocevar/git/ng3e-devel/root/R3.15.4/modules/busy-R1-6-1/dbd -I/home/hinkokocevar/git/ng3e-devel/root/R3.15.4/modules/calc-R5-4-2/dbd -I/home/hinkokocevar/git/ng3e-devel/root/R3.15.4/modules/sscan-R2-10-2/dbd -I/home/hinkokocevar/git/ng3e-devel/root/R3.15.4/modules/streamdevice-master/dbd -I/home/hinkokocevar/git/ng3e-devel/root/R3.15.4/modules/tlpm100-master/dbd -I/home/hinkokocevar/git/ng3e-devel/root/R3.15.4/base/dbd -o imgApp.dbd aravisCameraSupport.dbd tlccsSupport.dbd tlpm100Support.dbd drvAsynUSBTMC.dbd base.dbd stream.dbd asyn.dbd base.dbd NDPluginSupport.dbd ADSupport.dbd NDFileNull.dbd NDFileNetCDF.dbd NDFileTIFF.dbd NDFileJPEG.dbd NDFileNexus.dbd NDFileHDF5.dbd asyn.dbd asSupport.dbd busySupport.dbd calcSupport.dbd sscanSupport.dbd dbdExpand.pl: Duplicate definition of record type '' Context: recordtype(aai) in file '/home/hinkokocevar/git/ng3e-devel/root/R3.15.4/base/dbd/aaiRecord.dbd' in file '/home/hinkokocevar/git/ng3e-devel/root/R3.15.4/base/dbd/stdRecords.dbd' in file '/home/hinkokocevar/git/ng3e-devel/root/R3.15.4/base/dbd/base.dbd' while reading 'base.dbd' to create 'imgApp.dbd' dbdExpand.pl: Duplicate definition of record type '' Context: recordtype(asyn) in file '/home/hinkokocevar/git/ng3e-devel/root/R3.15.4/modules/asyn-ESS-R4-32+1/dbd/asynRecord.dbd' in file '/home/hinkokocevar/git/ng3e-devel/root/R3.15.4/modules/asyn-ESS-R4-32+1/dbd/asyn.dbd' in recordtype(aai) in file '/home/hinkokocevar/git/ng3e-devel/root/R3.15.4/base/dbd/aaiRecord.dbd' in file '/home/hinkokocevar/git/ng3e-devel/root/R3.15.4/base/dbd/stdRecords.dbd' in file '/home/hinkokocevar/git/ng3e-devel/root/R3.15.4/base/dbd/base.dbd' while reading 'asyn.dbd' to create 'imgApp.dbd' dbdExpand.pl: Exiting due to errors make[3]: *** No rule to make target '../O.Common/imgApp.dbd', needed by 'build'. Stop. make[3]: Leaving directory '/home/hinkokocevar/git/ng3e-devel/stage/R3.15.4/iocs/imgioc-master+2/imgApp/src/O.linux-x86_64' /home/hinkokocevar/git/ng3e-devel/root/R3.15.4/base/configure/RULES_ARCHS:61: recipe for target 'install.linux-x86_64' failed make[2]: *** [install.linux-x86_64] Error 2 make[2]: Leaving directory '/home/hinkokocevar/git/ng3e-devel/stage/R3.15.4/iocs/imgioc-master+2/imgApp/src' /home/hinkokocevar/git/ng3e-devel/root/R3.15.4/base/configure/RULES_DIRS:88: recipe for target 'src.install' failed make[1]: *** [src.install] Error 2 make[1]: Leaving directory '/home/hinkokocevar/git/ng3e-devel/stage/R3.15.4/iocs/imgioc-master+2/imgApp' /home/hinkokocevar/git/ng3e-devel/root/R3.15.4/base/configure/RULES_DIRS:88: recipe for target 'imgApp.install' failed Thank you, Hinko .. the more I see the less I believe.., AE AoR
ANJ, 21 Dec 2017 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
