There is a buffer overflow in "related display" with "a colum (or raw)
of buttons" visual. I reported to techtalk and already fixed in 3.1.13
which is available from github:
http://www.aps.anl.gov/epics/tech-talk/2017/msg00998.php
https://github.com/epics-extensions/medm/releases
# Indeed I'm using medm 3.1.11 on RHEL6 for production, and found the
problem when we were evaluating medm 3.1.11 on Ubuntu 1604.
best regards,
Shuei YAMADA
2017-10-25 23:55 GMT+09:00 Gerrit Kühn <[email protected]>:
> Hello,
> I found some issue here using medm 3.1.9:
> I'd like to use a "related display" with visual "a column of buttons".
> This works fine up to 14 labels. With adding the 15th label, I get a
> sigsev terminating medm. 15 items work fine using the "menu" visual, just
> the column of buttons appears to cause the issue. It also happens when
> starting off with a new screen, just containing this single related
> display.
> Can anyone reproduce this? Is this a bug (if so, where should I file it?),
> or am I doing something wrong?
> cu
> Gerrit
Shuei Yamada,
High Energy Accelerator Research Organization (KEK)
mailto:[email protected]
- Re: medm sigsev on related display Gerrit Kühn
- medm sigsev on related display Gerrit Kühn
Using the stream device @mismatch handler as an if conditional Paduan Donadio, Marcio
<2017>
<2017>
