1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: iocxxxInclude.dbd
To: <[email protected]>
Date: Thu, 26 Oct 2017 13:16:06 -0500
On 10/26/2017 11:42 AM, Rod Nussbaumer wrote:
> Your pattern for using find doesn't match the file you're trying to
> find; observe case sensitivity with respect to the 'I' in iocxxInclude.dbd
 From man find:
>  -iname pattern
>         Like -name, but the match is case insensitive.   For  example,  the
>         patterns  `fo*' and `F??' match the file names `Foo', `FOO', `foo',
>         `fOo', etc.   The pattern `*foo*` will also  match  a  file  called
>         '.foobar'.
I suspect the reason the find failed is because synapps modules have
moved on from using *Include.dbd files to putting a *_DBD list in the
Makefile, but that the autosave documentation hasn't caught up with that
change to the build configuration. I haven't checked that though.
- Andrew
> On 10/26/2017 08:11 AM, Sobhani, Bayan wrote:
>> The autosave documentation mentions adding ‘include “asSupport.dbd”’ to
>> iocxxInclude.dbd. However, when I type ‘find . -iname "*include*"’ in
>> the IOC’s top directory it returns nothing. What do I do if
>> iocxxxInclude.dbd doesn’t exist? Is there a way to get the IOC to
>> generate this file?
>> Alex
iocxxxInclude.dbd Sobhani, Bayan
Re: iocxxxInclude.dbd Rod Nussbaumer
Prev: Re: iocxxxInclude.dbd Rod Nussbaumer
Next: Controls Engineer Job at Brookhaven NSLS-II New York, USA Farnsworth, Richard
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
