1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: medm sigsev on related display
To: Gerrit Kühn <[email protected]>, <[email protected]>
Date: Wed, 25 Oct 2017 11:27:14 -0500
If you are using RHEL 7 or CentOS 7, check that you are not using motif-2.3.4-8.1 or motif-2.3.4-9. The latest version motif-2.3.4-10 should be fine. According to the change log on motif-2.3.4-10, they removed the "bug-fix" that caused problems in MEDM.
--Bob Soliday
On 10/25/2017 09:55 AM, Gerrit Kühn wrote:
Hello,
I found some issue here using medm 3.1.9:
I'd like to use a "related display" with visual "a column of buttons".
This works fine up to 14 labels. With adding the 15th label, I get a
sigsev terminating medm. 15 items work fine using the "menu" visual, just
the column of buttons appears to cause the issue. It also happens when
starting off with a new screen, just containing this single related
display.
Can anyone reproduce this? Is this a bug (if so, where should I file it?),
or am I doing something wrong?
cu
   Gerrit
Re: medm sigsev on related display Gerrit Kühn
Prev: Re: medm sigsev on related display Mark Rivers
Next: Re: medm sigsev on related display Mooney, Tim M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: Re: medm sigsev on related display Gerrit Kühn
Next: Re: medm sigsev on related display Gerrit Kühn
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
