1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: medm sigsev on related display
To: "Mooney, Tim M." <[email protected]>
Date: Wed, 25 Oct 2017 16:04:23 +0000
Are you using a column of buttons which seems to be the problem?
Sent from my iPhone
On Oct 25, 2017, at 11:50 AM, Mooney, Tim M. <[email protected]<mailto:[email protected]>> wrote:
I have menus with 16 items, and I haven't seen this problem.  I'm running 3.1.11.
I don't have ready access to 3.1.9, but I can run with 3.1.7, and it also doesn't show the problem.  I'm running Redhat 6.
Tim Mooney ([email protected]<mailto:[email protected]>) (630)252-5417
Beamline Controls Group (www.aps.anl.gov<http://www.aps.anl.gov>)
Advanced Photon Source, Argonne National Lab
From: [email protected]<mailto:[email protected]> <[email protected]<mailto:[email protected]>> on behalf of Gerrit Kühn <[email protected]<mailto:[email protected]>>
Sent: Wednesday, October 25, 2017 9:55:18 AM
To: [email protected]<mailto:[email protected]>
Subject: medm sigsev on related display
Hello,
I found some issue here using medm 3.1.9:
I'd like to use a "related display" with visual "a column of buttons".
This works fine up to 14 labels. With adding the 15th label, I get a
sigsev terminating medm. 15 items work fine using the "menu" visual, just
the column of buttons appears to cause the issue. It also happens when
starting off with a new screen, just containing this single related
display.
Can anyone reproduce this? Is this a bug (if so, where should I file it?),
or am I doing something wrong?
cu
  Gerrit
Re: medm sigsev on related display Mooney, Tim M.
medm sigsev on related display Gerrit Kühn
Prev: Re: medm sigsev on related display Mooney, Tim M.
Next: Re: medm sigsev on related display Bob Soliday
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Next: Re: medm sigsev on related display Mooney, Tim M.
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
