I use pyinstaller to compile the python script to exe file in centos7 system that contained the following line
from CaChannel import ca, CaChannel
When executing the exe file and an error occured :
[user@localhost dist]$ ./1-ok
/tmp/_MEIxRN9gA/CaChannel/ca.py:13: RuntimeWarning: c extension is not available, trying caffi as fallback
Traceback (most recent call last):
File "1-ok.py", line 4, in <module>
File "/usr/lib/python2.7/site-packages/PyInstaller/loader/pyimod03_importers.py", line 396, in load_module
exec(bytecode, module.__dict__)
File "CaChannel/__init__.py", line 3, in <module>
File "CaChannel/CaChannel.py", line 15, in <module>
File "CaChannel/ca.py", line 14, in <module>
ImportError: No module named caffi.ca
[26510] Failed to execute script 1-ok
It seems I have to enter the absoult path of caffi.ca when using pyinstaller.
I have installed the cachannel by using the command:
sudo easy_install cachannel
I have no idea what the path of caffi.ca is under centos7 system or other methods to solve the problem.
Any help will be appreciated and thanks in advance!
Zhefu
