1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: caputRecorder make error
To: l123173 <[email protected]>, "Zimoch Dirk (PSI)" <[email protected]>
Date: Wed, 18 Oct 2017 16:56:32 +0000
Can you post your modified RELEASE file of caputRecorder?
Did you modify your setting of EPICS base?
If not, the only setting you have to change is the EPICS_BASE.
Either the one comes with synapps, or the one from github should be compiled as it is.
Guobao
From: <[email protected]> on behalf of l123173 <[email protected]>
Date: Wednesday, October 18, 2017 at 11:06 AM
To: "Zimoch Dirk (PSI)" <[email protected]>
Hi Dirk.
I have set it in ~/.bash_profile
发自网易邮箱大师
On 10/18/2017 23:59, Zimoch Dirk (PSI) wrote:
It seems your EPICS_HOST_ARCH environment variable is not set.
Dirk
Am 18.10.2017 um 15:52 schrieb l123173 <[email protected]>:
Hi all,
    I have installed synapps_5_8, base-3.15.3, centos 7.
    Base was ok. When I make synapps, caputRecordes has error, so I downloaded the newest caputRecorder from github( https://github.com/epics-modules/caputRecorder )
   Then I modified RELEASE in caputRecorder.
but  it said:  (base was in /opt/base-3.15.3)
[root@localhost caputRecorder-master]# make
/opt/base-3.15.3/configure/CONFIG:56: /opt/base-3.15.3/configure/os/CONFIG..Common: No such file or directory
make: *** No rule to make target `/opt/base-3.15.3/configure/os/CONFIG..Common'.  Stop.
How could I fixed it?
Thans,
Li xing
caputRecorder make error l123173
Re: caputRecorder make error Zimoch Dirk (PSI)
Re: caputRecorder make error l123173
Prev: Re: caputRecorder make error l123173
Next: Looking for a Beckhoff PLC Expert!! Wallace, Alex
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
