Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: Re: caputRecorder make error
To: "Zimoch Dirk (PSI)" <dirk.zimoch@psi.ch>
Cc: tech-talk <tech-talk@aps.anl.gov>
Date: Thu, 19 Oct 2017 00:03:14 +0800 (GMT+08:00)
It seems your EPICS_HOST_ARCH environment variable is not set.
Dirk
Am 18.10.2017 um 15:52 schrieb l123173 <l123173@163.com>:
Hi all,
    I have installed synapps_5_8, base-3.15.3, centos 7.
    Base was ok. When I make synapps, caputRecordes has error, so I downloaded the newest caputRecorder from github( https://github.com/epics-modules/caputRecorder )
   Then I modified RELEASE in caputRecorder.
but  it said:  (base was in /opt/base-3.15.3)
[root@localhost caputRecorder-master]# make
/opt/base-3.15.3/configure/CONFIG:56: /opt/base-3.15.3/configure/os/CONFIG..Common: No such file or directory
make: *** No rule to make target `/opt/base-3.15.3/configure/os/CONFIG..Common'.  Stop.
How could I fixed it?
Thans,
Li xing
Re: caputRecorder make error Shen, Guobao
caputRecorder make error l123173
Re: caputRecorder make error Zimoch Dirk (PSI)
Prev: Re: caputRecorder make error Zimoch Dirk (PSI)
Next: Re: caputRecorder make error Shen, Guobao
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
ANJ, 18 Oct 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
