Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: RE: caQtDM installation help needed
From: "Antal, Szabolcs" <Szabolcs.Antal@evopro-group.com>
To: "Williams Jr., Ernest L." <ernesto@slac.stanford.edu>, "tech-talk@aps.anl.gov" <tech-talk@aps.anl.gov>
Date: Wed, 18 Oct 2017 09:24:44 +0000
Hi!
Thank you all for your aid! Unfortunately I cannot get to the final breakthrough :(
I'm not sure that I made a proper installation for Qt5 and qwt.
Anyone of you have installed caQtDM on Ubuntu, if so please can you help me get to the
right direction because now I'm kinda stuck with this project.
I can share my installation process so maybe you can find a mistake that can be the root of my troubles:
Qt5.6.3:
	- Downloaded qt-opensource-linux-x64-5.6.3.run
	- chmod +x qt-opensource-linux-x64-5.6.3.run
	- ./qt-opensource-linux-x64-5.6.3.run
	- Followed the instructions within the installer wizard, and set the installation folder to /usr/local/Qt5.6.3
	- After a succesful installation I also installed some other dependencies:
		- sudo apt-get install mesa-common-dev (installed because qwt install has thrown -> fatal error: GL/gl.h: No such file or directory)
		- sudo apt-get install libglu1-mesa-dev (installed because qwt install has thrown -> cannot find -lGL)
qwt-6.1.3:
	- Downloaded qwt-6.1.3.tar.bz2 and extracted it to folder qwt-6.1.3
	- cd qwt-6.1.3
	- /usr/local/Qt5.6.3/5.6.3/gcc_64/bin/qmake qwt.pro
	- make (success)
	- sudo make install (success)
From here I tried several methods to install caQtDM without success, so if anyone of you have hands-on experience with
Ubuntu and caQtDM together I'd really appreciate the knowledge share!
Again thank you all for your efforts!
Yours truly,
____________________
Szabolcs Antal
Software Developer
evopro systems engineering Kft.
member of the evopro group
-----Original Message-----
From: Williams Jr., Ernest L. [mailto:ernesto@slac.stanford.edu]
Sent: Tuesday, October 17, 2017 3:50 PM
To: Antal, Szabolcs <Szabolcs.Antal@evopro-group.com>; tech-talk@aps.anl.gov
Hi Antal,
Before attempting to build be sure to setup your environment first:
I started with Qt5.4.1  ages ago. :)
An example, follows for those who use the unix bash shell:
Note: PACKAGE_TOP is the location that you installed your packages ==> Qt5.x and qwt 6.1.x Just replace $PACKAGE_TOP as appropriate with your  "/opt" or "/usr/local"
# Let's setup for caQtDM: From PSI
# Display Editor and Manager for Control System GUI Development # Both Editor/Runtime # Using QT5 and QWT # ==========================================================
QTDIR=$PACKAGE_TOP/Qt-5.4.1
QTINC=$PACKAGE_TOP/Qt-5.4.1/include
QTLIB=$PACKAGE_TOP/Qt-5.4.1/lib
export QT_PLUGIN_PATH="${QTDIR}/plugins"
export PATH=$QTDIR/bin:$PATH
# QWT Setup
export QWT_ROOT=$PACKAGE_TOP/qwt-6.1.2
export QT_PLUGIN_PATH="${QWT_ROOT}/plugins:$QT_PLUGIN_PATH"
# Plugin location for caQtDM and epicsQT # ==========================================================
export QT_PLUGIN_PATH="${EPICS_EXTENSIONS}/lib/${EPICS_HOST_ARCH}:$QT_PLUGIN_PATH"
Note: you can put the above in a file and source it before building caQtDM
Cheers,
Ernesto
From: tech-talk-bounces@aps.anl.gov [tech-talk-bounces@aps.anl.gov] on behalf of Antal, Szabolcs [Szabolcs.Antal@evopro-group.com]
Sent: Tuesday, October 17, 2017 5:33 AM
To: tech-talk@aps.anl.gov
Subject: caQtDM installation help needed
Dear Folks,
I'm in a bit of trouble with the installation of caQtDM-4.1.5 on Ubuntu 16.04.
As the installation notes says the prerequisites are Qt5.x and qwt 6.1.x and Qt Designer (however I'm not sure whether I need Qt Designer if I have Qt Creator installed with Qt5.6.3).
I managed to install Qt5.6.3 to /opt/Qt5.6.3/ and qwt6.1.3 at /usr/local/qwt-6.1.3/.
I extracted the caQtDM archive to /usr/local/epics/extension/src/caqtdm-4.1.5.
However I'm not sure how to set the configuration variables inside caQtDM_Env.
Also a broken qt4 installation can be found on the system and it seems like the caQtDM_Build script tries to use that one during installation as I get the following error message when I run the script:
qmake: could not exec '/usr/lib/x86_64-linux-gnu/qt4/bin/qmake': No such file or directory
I'm a bit stuck at the moment, so any help regarding to the overall installation of caQtDM with the mentioned prerequisites would be greatly appreciated!
Thank you in advance!
Yours truly,
Szabolcs Antal
Software Developer
[cid:companylogo]
Ez az e-mail (ideértve annak bármely mellékletét) bizalmas információkat tartalmaz és jogi védelem alatt áll. Az üzenet kizárólag a címzett(ek)nek szól. Amennyiben Ön nem a küldemény címzettje, úgy a téves kézbesítést kérjük haladéktalanul jelezze e-mailben a feladónak és a teljes küldeményt helyreállíthatatlanul törölje. Amennyiben Ön nem az üzenet címzettje, kérjük ne készítsen másolatot az üzenetről, ne továbbítsa, ne tárja fel és ne tegye hozzáférhetővé azt más személy(ek) számára, továbbá semmilyen célra ne használja fel a bizalmas információt: ezen magatartások bármelyike a levéltitok megsértésének minősül.
Information in this e-mail (including any attachment hereto) is confidential and may be legally privileged. It is intended solely for the attention of the addressee(s). If you received this message in error, please immediately notify the sender by return e-mail and irrecoverably delete the whole message. If you received this e-mail in error, please do not copy it, do not forward, disclose or make it available to other person(s), and do not use the confidential information for any purpose: any such action is regarded as a breach of confidence.
Re: caQtDM installation help needed Jiro Fujita
caQtDM installation help needed Antal, Szabolcs
RE: caQtDM installation help needed Williams Jr., Ernest L.
Prev: Re: aCalcout: how to obtain scalar from array? Paduan Donadio, Marcio
Next: Re: Problems with motor record Jörn Dreyer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Prev: RE: caQtDM installation help needed Williams Jr., Ernest L.
Next: Re: caQtDM installation help needed Jiro Fujita
ANJ, 19 Oct 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
