Hi Antal,
Before attempting to build be sure to setup your environment first:
I started with Qt5.4.1 ages ago. :)
An example, follows for those who use the unix bash shell:
Note: PACKAGE_TOP is the location that you installed your packages ==> Qt5.x and qwt 6.1.x
Just replace $PACKAGE_TOP as appropriate with your "/opt" or "/usr/local"
# Let's setup for caQtDM: From PSI
# Display Editor and Manager for Control System GUI Development
# Both Editor/Runtime
# Using QT5 and QWT
QTDIR=$PACKAGE_TOP/Qt-5.4.1
QTINC=$PACKAGE_TOP/Qt-5.4.1/include
QTLIB=$PACKAGE_TOP/Qt-5.4.1/lib
export QT_PLUGIN_PATH="${QTDIR}/plugins"
export PATH=$QTDIR/bin:$PATH
# QWT Setup
export QWT_ROOT=$PACKAGE_TOP/qwt-6.1.2
export QT_PLUGIN_PATH="${QWT_ROOT}/plugins:$QT_PLUGIN_PATH"
# Plugin location for caQtDM and epicsQT
export QT_PLUGIN_PATH="${EPICS_EXTENSIONS}/lib/${EPICS_HOST_ARCH}:$QT_PLUGIN_PATH"
Note: you can put the above in a file and source it before building caQtDM
Cheers,
Ernesto
From: [email protected] [[email protected]] on behalf of Antal, Szabolcs [[email protected]]
Sent: Tuesday, October 17, 2017 5:33 AM
To: [email protected]
Subject: caQtDM installation help needed
Dear Folks,
I’m in a bit of trouble with the installation of caQtDM-4.1.5 on Ubuntu 16.04.
As the installation notes says the prerequisites are Qt5.x and qwt 6.1.x and Qt Designer (however I’m not sure whether I need Qt Designer if I have Qt Creator installed with Qt5.6.3).
I managed to install Qt5.6.3 to /opt/Qt5.6.3/ and qwt6.1.3 at /usr/local/qwt-6.1.3/.
I extracted the caQtDM archive to /usr/local/epics/extension/src/caqtdm-4.1.5.
However I’m not sure how to set the configuration variables inside caQtDM_Env.
Also a broken qt4 installation can be found on the system and it seems like the caQtDM_Build script tries to use that one
during installation as I get the following error message when I run the script:
qmake: could not exec '/usr/lib/x86_64-linux-gnu/qt4/bin/qmake': No such file or directory
I’m a bit stuck at the moment, so any help regarding to the overall installation of caQtDM with the mentioned prerequisites
would be greatly appreciated!
Thank you in advance!
Yours truly,
Szabolcs Antal
Software Developer
[cid:companylogo]
evopro systems engineering Kft.
member of the evopro group
Ez az e-mail (ideértve annak bármely mellékletét) bizalmas információkat tartalmaz és jogi védelem alatt áll. Az üzenet kizárólag a címzett(ek)nek szól. Amennyiben Ön nem a küldemény címzettje, úgy a téves kézbesítést kérjük haladéktalanul jelezze e-mailben a feladónak és a teljes küldeményt helyreállíthatatlanul törölje. Amennyiben Ön nem az üzenet címzettje, kérjük ne készítsen másolatot az üzenetről, ne továbbítsa, ne tárja fel és ne tegye hozzáférhetővé azt más személy(ek) számára, továbbá semmilyen célra ne használja fel a bizalmas információt: ezen magatartások bármelyike a levéltitok megsértésének minősül.
Information in this e-mail (including any attachment hereto) is confidential and may be legally privileged. It is intended solely for the attention of the addressee(s). If you received this message in error, please immediately notify the sender by return e-mail and irrecoverably delete the whole message. If you received this e-mail in error, please do not copy it, do not forward, disclose or make it available to other person(s), and do not use the confidential information for any purpose: any such action is regarded as a breach of confidence. Attachment:
Description: image002.png
- RE: caQtDM installation help needed Antal, Szabolcs
- caQtDM installation help needed Antal, Szabolcs
Re: Problems with motor record Jörn Dreyer
Re: caQtDM installation help needed Mooney, Tim M.
<2017>
Re: caQtDM installation help needed Pete Jemian
<2017>
