1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS areadetecto and EPICSV4
To: [email protected]
Date: Wed, 11 Oct 2017 11:12:09 +0200
Thanks Mark,
that solved the problem. I'm only puzzled why I can not define those variables
in CONFIG_SITE.local. Doing so results in the exact same problem.
Jörn
Am Mittwoch, 11. Oktober 2017, 11:02:54 CEST schrieb Mark Rivers:
> Hi Jörn,
> Does your IOC configure/RELEASE file define the individual V4 modules?  It
> needs to do this:
> PVCOMMON=$(EV4_BASE)/pvCommonCPP
> PVACCESS=$(EV4_BASE)/pvAccessCPP
> PVDATA=$(EV4_BASE)/pvDataCPP
> PVDATABASE=$(EV4_BASE)/pvDatabaseCPP
> NORMATIVETYPES=$(EV4_BASE)/normativeTypesCPP
> If you still have problems please send the complete make output when you
> rebuild your IOC application.
> Mark
> From: [email protected] [[email protected]] on
> behalf of Jörn Dreyer [[email protected]] Sent: Wednesday, October 11, 2017
> 3:40 AM
> Hi Mark,
> in the areadetektor I have set up EV4_BASE correctly. Maybe I was not clear
> in my firs mail. I'm developing the IOC outside of the areadetector
> directory structure and thus not using its internal config files. But my
> environment defines EV4_BASE.
> Regards,
> Jörn
> Am Dienstag, 10. Oktober 2017, 14:28:14 CEST schrieb Mark Rivers:
> > HI Jörn,
> > I am successfully doing what you are trying to do using RELEASE*.local
> > files that are identical to the EXAMPLE_RELEASE*.local files in the
> > master branch of  areaDetector/configure.
> > I suspect you did not define the path to the V4 libraries in
> > RELEASE_PATHS.local.  This is the symbol EV4_BASE. My version of that file
> > contains these lines:
> > # If CONFIG_SITE.local defines WITH_EPICS_V4=YES then define the path here
> > EV4_BASE     = /corvette/usr/local/epics-devel/epicsV4/EPICS-CPP-4.6.0
> > RELEASE_LIBS.local contains these lines:
> > # V4 modules.
> > Let me know if you still have problems.
> > Mark
> > behalf of Jörn Dreyer [[email protected]] Sent: Tuesday, October 10, 2017
> > 7:14 AM
> > Subject: EPICS areadetecto and EPICSV4
> > Hi all,
> > I have a probably stupid question concerning the use of EPICS V4 and the
> > areadetector code in an IOC.
> > I'm trying to build an IOC with which I want to readout a GiGE based
> > camera. To do performance comparisons I also want to include the EPICS V4
> > code. But If I enable WITH_EPICS_V4 in the Makefile, I fail to find the
> > „../../../lib/linux- x86_64/libpvDatabase.a“ The makefile is searching in
> > the wrong directories. I included
> > include $(AREADETECTOR)/ADCore/ADApp/commonDriverMakefile
> > in my IOC makefile. And therein the EPICS V4 libraries are added to
> > PROD_LIBS. What variable do I need to set so that make will find those
> > libraries? If I change PROD_LIBS to PROD_SYS_LIBS, everything compiles
> > fine.
> > With kind regards,
> > Jörn Dreyer
RE: EPICS areadetecto and EPICSV4 Mark Rivers
EPICS areadetecto and EPICSV4 Jörn Dreyer
Re: EPICS areadetecto and EPICSV4 Jörn Dreyer
Prev: RE: EPICS areadetecto and EPICSV4 Mark Rivers
Next: RE: EPICS areadetecto and EPICSV4 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
