1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: RE: EPICS areadetecto and EPICSV4
To: Jörn Dreyer <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 10 Oct 2017 12:28:14 +0000
HI Jörn,
I am successfully doing what you are trying to do using RELEASE*.local files that are identical to the EXAMPLE_RELEASE*.local files in the master branch of  areaDetector/configure.
I suspect you did not define the path to the V4 libraries in RELEASE_PATHS.local.  This is the symbol EV4_BASE. My version of that file contains these lines:
# If CONFIG_SITE.local defines WITH_EPICS_V4=YES then define the path here
EV4_BASE     = /corvette/usr/local/epics-devel/epicsV4/EPICS-CPP-4.6.0
RELEASE_LIBS.local contains these lines:
# V4 modules.
PVCOMMON=$(EV4_BASE)/pvCommonCPP
PVACCESS=$(EV4_BASE)/pvAccessCPP
PVDATA=$(EV4_BASE)/pvDataCPP
PVDATABASE=$(EV4_BASE)/pvDatabaseCPP
NORMATIVETYPES=$(EV4_BASE)/normativeTypesCPP
Let me know if you still have problems.
From: [email protected] [[email protected]] on behalf of Jörn Dreyer [[email protected]]
Sent: Tuesday, October 10, 2017 7:14 AM
To: [email protected]
Subject: EPICS areadetecto and EPICSV4
Hi all,
I have a probably stupid question concerning the use of EPICS V4 and the
areadetector code in an IOC.
I'm trying to build an IOC with which I want to readout a GiGE based camera.
To do performance comparisons I also want to include the EPICS V4 code. But If
I enable WITH_EPICS_V4 in the Makefile, I fail to find the  „../../../lib/linux-
x86_64/libpvDatabase.a“ The makefile is searching in the wrong directories. I
included
include $(AREADETECTOR)/ADCore/ADApp/commonDriverMakefile
in my IOC makefile. And therein the EPICS V4 libraries are added to PROD_LIBS.
What variable do I need to set so that make will find those libraries? If I
change PROD_LIBS to PROD_SYS_LIBS, everything compiles fine.
With kind regards,
Jörn Dreyer
Re: EPICS areadetecto and EPICSV4 Ralph Lange
Re: EPICS areadetecto and EPICSV4 Jörn Dreyer
Prev: EPICS areadetecto and EPICSV4 Jörn Dreyer
Next: Re: EPICS areadetecto and EPICSV4 Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
