1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: init function in device support
To: Michael Davidsaver <[email protected]>
Cc: "[email protected] Talk" <[email protected]>
Date: Fri, 6 Oct 2017 20:16:50 +0000
Thank you, the init hook seems to work perfectly.
-Patrick
Sent: Friday, October 6, 2017 1:53 AM
To: Thomas, Patrick
Cc: [email protected] Talk
On 10/06/2017 02:04 AM, Thomas, Patrick wrote:
> Hi,
> I am trying to understand how to use the 'long init(int after)' function
> in device support. Is it expected that I define a separate such function
> for each record type (there is a pointer to it in the dset for each
> record type)? I would like to define a single function that gets called
> after all records of *all types* have been initialized. Is this
> possible? If so, is there an example available?
The device support init() function isn't required, and may be omitted.
IMO it's not very useful.  I've never had record type/DTYP specific
initialization.
What you want is best accomplished with an init hook (see initHooks.h).
My usual starting point is to call initHookRegister() from a registrar
function, then use the initHookAfterIocRunning event to start eg. driver
specific worker threads.  This happens near the end of iocInit().
init function in device support Thomas, Patrick
Re: init function in device support Michael Davidsaver
Prev: Re: Basic String Concatenation in EPICS Mooney, Tim M.
Next: Re: Asyn GPIB proto file exception @writetimeout Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: Re: init function in device support Michael Davidsaver
Next: aD driver for Mako G G-032? Ralph Lange
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
