1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: init function in device support
To: "[email protected] Talk" <[email protected]>
Date: Fri, 6 Oct 2017 00:04:59 +0000
I am trying to understand how to use the 'long init(int after)' function in device support. Is it expected that I define a separate such function for each record type (there is a pointer to it in the dset for each record type)? I would like to define a single function that gets called after all records of *all types* have been initialized. Is this possible? If so, is there an example available?
Thank you for your time,
Patrick
Re: init function in device support Johnson, Andrew N.
Re: init function in device support Michael Davidsaver
Prev: Re: New modular EPICS Base structure is active Benjamin Franksen
Next: Re: init function in device support Johnson, Andrew N.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
