Hello,
currently I'm working on a piezo motor driver based on the
asynMotorController. At startup of the IOC the Axis::move command is called
with parameters that I do not understand. If I put a printout statement at the
beginning of the function like this:
printf("%s %d %s %f %d %f %f %f\n", "Moving axis", axisNo_+1, "to position",
position, relative, minVelocity, maxVelocity, acceleration);
it results in:
Moving axis 1 to position inf 0 0.000000 0.000000 0.000000
The corresponding record looks like this:
record(motor, "A:m1") {
field(DESC, "Mirror 1")
field(DTYP, "asynMotor")
field(DIR, "1")
field(VELO, "110.")
field(VBAS, ".05")
field(ACCL, ".5")
field(BDST, "0")
field(BVEL, "1.0")
field(BACC, "2")
field(OUT, "@asyn(B,0)")
field(MRES, "0.00001")
field(PREC, "5")
field(EGU, "mm")
field(DHLM, "0.32768")
field(DLLM, "1")
field(INIT, "")
field(RTRY, "5")
field(TWV, "1")
field(SDIS, "A:m1_able.VAL")
field(VMAX, "190.")
It gets called three times, first with inf, then with DHLM, and then with
10000. Looks like it wants to do something like homing. How can I prevent
this?
Jörn
- Re: Motor module problem Torsten Bögershausen
Re: registerRecordDeviceDriver.pl takes a long time to finish Luca Cavalli
<2017>
Re: Record processing twice after upgrading to Base 3.15.5 Andrew Johnson
<2017>
