can Perl profiling be of any help here?
install NYTProf Perl package, then build your IOC with:
$ export NYTPROF=addpid=1
$ PERL5OPT=-d:NYTProf make
Locate the correct nytprof.out.<pid> and open it with
$ nytprofhtml -f nytprof.out.<pid> --open
Hope it helps,
Luca
On Wed, 2017-09-27 at 12:15 +0200, Hinko Kocevar wrote:
Under 3.15.4 perl script execution takes a lot of time on Linux Mint, while it executes in a jiffy on CentOS.
I added a time in front of the perl call in RULES.db:
time perl -CSD /devel/root/R3.15.4/base/bin/linux-x86_64/registerRecordDeviceDriver.pl -I. -I.. -I../O.Common -I../../../dbd -I/devel/root/R3.15.4/modules/adcore-master/dbd -I/devel/root/R3.15.4/modules/adsimdetector-master/dbd -I/devel/root/R3.15.4/modules/asyn-master/dbd
-I/devel/root/R3.15.4/modules/autosave-master/dbd -I/devel/root/R3.15.4/modules/busy-master/dbd -I/devel/root/R3.15.4/modules/calc-master/dbd -I/devel/root/R3.15.4/modules/sscan-master/dbd -I/devel/root/R3.15.4/base/dbd -o simDetectorApp_registerRecordDeviceDriver.cpp
../O.Common/simDetectorApp.dbd simDetectorApp_registerRecordDeviceDriver /devel/stage/R3.15.4/iocs/simdetectorioc-master
29.95user 0.02system 0:29.98elapsed 99%CPU (0avgtext+0avgdata 19256maxresident)k
I think other calls to perl are awfully slow, too..
Any idea why it might be so slow?
Hinko
<< Le informazioni contenute in questo messaggio di posta elettronica e relativi allegati sono riservate e confidenziali e ne è vietata la diffusione in qualunque modo eseguita. Qualora Lei non fosse la persona a cui il presente messaggio è destinato, La invitiamo
ad eliminarlo e a darcene gentile comunicazione. Quanto precede ai fini del rispetto delle Legge 675/96 e del Decreto Legislativo 30/06/2003 n.196, sulla tutela dei dati personali >>
<< This e-mail is confidential and may well also be legally privileged. If you have received it in error, you are on notice of its status. Please notify us immediately by reply e-mail and then delete this message from your system. Please do not copy it or use
it for any purposes, or disclose its contents to any other person: to do so could be a breach of confidence. Thank you for your co-operation. Please contact our IT Helpdesk on +3902380481 or email [email protected] if you need assistance >>
- Re: registerRecordDeviceDriver.pl takes a long time to finish Andrew Johnson
- registerRecordDeviceDriver.pl takes a long time to finish Hinko Kocevar
Re: Record processing twice after upgrading to Base 3.15.5 Andrew Johnson
Motor module problem Jörn Dreyer
<2017>
Re: registerRecordDeviceDriver.pl takes a long time to finish Michael Davidsaver
<2017>
