If these are static values there is another possible workaround, you can hardcode them in the XML layout file. From the docs at
http://cars.uchicago.edu/software/epics/NDFileHDF5.html
XML attribute
Required
Description
Value
value
Required only if source="constant"
Constant value to write directly into the HDF5 dataset
String - possibly containing int or float values. Arrays of int and float values can also be represented in a comma-separated string
Tom
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of Hinko Kocevar
> Sent: 26 September 2017 13:42
> To: Mark Rivers
> Cc: [email protected]
> Subject: Re: save array of floats into HDF5 as attribute
> Hi Mark,
> thanks for explaining! I managed to get the FTVL=CHAR waveforms to
> appear as strings in the HDF5 file, on another occasion.
> What I want to save now are coefficients that need to be floats, chars
> (FTVL=CHAR) will not cut it.
> I'll resort to defining 10 ai records instead of one waveform for now, since I
> need this in the coming days/weeks.
> Will keep an eye on the #2 issue, though!
> Thanks,
> Hinko
> On Tue, Sep 26, 2017 at 2:19 PM, Mark Rivers <[email protected]>
> wrote:
> I have updated the Github issue to raise the possibility of supporting
> arrays in NDAttributes by storing them as strings.
https://github.com/areaDetector/ADCore/issues/2
> <https://github.com/areaDetector/ADCore/issues/2>
> Mark
> ________________________________
> From: Mark Rivers
> Sent: Tuesday, September 26, 2017 7:12 AM
> To: Hinko Kocevar;
[email protected]
> Subject: RE: save array of floats into HDF5 as attribute
> Hi Hinko,
> > can I save an array of floats into HDF5 file through areaDetector
> Attribute?
> No, unfortunately that is not possible. There is a 4 year old issue in
> ADCore about this:
> This is from NDAttribute.h
> /** Union defining the values in an NDAttribute object */
> typedef union {
> epicsInt8 i8; /**< Signed 8-bit integer */
> epicsUInt8 ui8; /**< Unsigned 8-bit integer */
> epicsInt16 i16; /**< Signed 16-bit integer */
> epicsUInt16 ui16; /**< Unsigned 16-bit integer */
> epicsInt32 i32; /**< Signed 32-bit integer */
> epicsUInt32 ui32; /**< Unsigned 32-bit integer */
> epicsFloat32 f32; /**< 32-bit float */
> epicsFloat64 f64; /**< 64-bit float */
> } NDAttrValue;
> /** Structure used by the EPICS ellLib library for linked lists of C++
> objects.
> * This is needed for ellLists of C++ objects, for which making the
> first data element the ELLNODE
> * does not work if the class has virtual functions or derived classes.
> typedef struct NDAttributeListNode {
> ELLNODE node;
> class NDAttribute *pNDAttribute;
> } NDAttributeListNode;
> /** NDAttribute class; an attribute has a name, description, source
> type, source string,
> * data type, and value.
> class epicsShareClass NDAttribute {
> public:
> /* Methods */
> NDAttribute(const char *pName, const char *pDescription,
> NDAttrSource_t sourceType, const char *pSource,
> NDAttrDataType_t dataType, void *pValue);
> NDAttribute(NDAttribute& attribute);
> static const char *attrSourceString(NDAttrSource_t type);
> virtual ~NDAttribute();
> virtual NDAttribute* copy(NDAttribute *pAttribute);
> virtual const char *getName();
> virtual const char *getDescription();
> virtual const char *getSource();
> virtual const char *getSourceInfo(NDAttrSource_t *pSourceType);
> virtual NDAttrDataType_t getDataType();
> virtual int getValueInfo(NDAttrDataType_t *pDataType, size_t
> *pDataSize);
> virtual int getValue(NDAttrDataType_t dataType, void *pValue,
> size_t dataSize=0);
> virtual int getValue(std::string& value);
> virtual int setDataType(NDAttrDataType_t dataType);
> virtual int setValue(const void *pValue);
> virtual int setValue(const std::string&);
> virtual int updateValue();
> virtual int report(FILE *fp, int details);
> friend class NDArray;
> friend class NDAttributeList;
> private:
> template <typename epicsType> int getValueT(void *pValue,
> size_t dataSize);
> std::string name_; /**< Name string */
> std::string description_; /**< Description string */
> NDAttrDataType_t dataType_; /**< Data type of attribute */
> NDAttrValue value_; /**< Value of attribute except for
> strings */
> std::string string_; /**< Value of attribute for strings */
> std::string source_; /**< Source string - EPICS PV name or
> DRV_INFO string */
> NDAttrSource_t sourceType_; /**< Source type */
> std::string sourceTypeString_; /**< Source type string */
> NDAttributeListNode listNode_; /**< Used for NDAttributeList */
> So the value_ member is a union of the numeric data types, and it
> can store only a single value.
> The exception is for strings, where the value is stored in the
> std::string string_ member. There is effectively no length limit on strings.
> If you change from DBR_NATIVE to DBR_STRING it will read the
> entire array as a string if the waveform record FTVL is CHAR. So I was hoping
> this would work to read your array:
> <Attribute name="GaussParams" type="EPICS_PV"
> source="DTU:GaussParams" dbrtype="DBR_STRING" description="Gauss
> params"/>
> However, I just tested this with a waveform record whose FTVL is
> DOUBLE and it only reads the first element, not the entire array. I think that
> is something that would not be too hard to fix: if the requested
> dbrtype=DBR_STRING then subscribe for callbacks on the entire array, not
> just the first element.
> Would that be useful for you, i.e. having the array as a string rather
> than 10 numbers?
> Mark
> From:
[email protected] [tech-talk-
> [email protected]] on behalf of Hinko Kocevar [[email protected]]
> Sent: Tuesday, September 26, 2017 3:44 AM
> To:
[email protected]
> Subject: AD: save array of floats into HDF5 as attribute
> Hi,
> Attribute?
> XML definition:
> source="DTU:GaussParams" dbrtype="DBR_NATIVE"
> description="Gauss params"/>
> where PV is:
> record(waveform, "$(P)$(R)GaussParams")
> field(FTVL, "DOUBLE")
> field(NELM, "10")
> With the above, I only a single (first) value saved in the HDF5 file as
> opposed to all 10.
> Thanks,
> Hinko
> .. the more I see the less I believe.., AE AoR
