Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: AD: save array of floats into HDF5 as attribute
To: "tech-talk@aps.anl.gov" <tech-talk@aps.anl.gov>
Date: Tue, 26 Sep 2017 10:44:52 +0200
can I save an array of floats into HDF5 file through areaDetector Attribute?
XML definition:
<Attribute name="GaussParams"         type="EPICS_PV" source="DTU:GaussParams"                dbrtype="DBR_NATIVE"  description="Gauss params"/>
where PV is:
record(waveform, "$(P)$(R)GaussParams")
field(FTVL, "DOUBLE")
field(NELM, "10")
With the above, I only a single (first) value saved in the HDF5 file as opposed to all 10.
Hinko
.. the more I see the less I believe.., AE AoR
Prev: RE: Coordinated motion with EPICS motor record Mark Rivers
Next: RE: save array of floats into HDF5 as attribute Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Prev: RE: Coordinated motion with EPICS motor record So, Sung-Leung
ANJ, 26 Sep 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
