Hi all,
I am trying to modified drvScaler974.cpp( driver of 974 scaler ) to drvScalerCT08E.cpp in std of synapps.
CT08E was a new scaler(
http://www.tsuji-denshi.co.jp/english/download.html ), which has not driver in std.
In a word, I want to write the driver of CT08E base on drvScaler974.cpp in std-3-4.
The command was uncomplex. I modified the relevant command, such as clear,start and stop. But command of new scaler about "set timer", "get value of channel" was much different from 974scaler.
The new scaler command about "set timer": If I sent TPR%d(%d was millsecond), the scaler would set the timer.
The new scaler command about "get value of channel": If I sent RDAL, I should get 9 number(channel 0-7 and the timer), whose format was 0000000000 000000000 0000000000 0000000000 0000000000 0000000000 0000000000 0000000000 0000000000, nine 10 bit number divide by space. And the laset number(timer) continue increase until it equal the set time which TPR command set.
Rebuild std and ioc was ok, the ioc could run with no error except the write/read.
I am using base 3.15.2, Synapps5_8, std-3-4, Centos 7(64).
The driver file and output was following.
How could I do it to achieve these function?
Could you give me some suggestion.
Thank you,
Liang yx
The content of drvScalerCT08E.cpp which I modified.
#include <stdlib.h>
#include <stddef.h>
#include <string.h>
#include <stdio.h>
#include <math.h>
/* EPICS includes */
#include <asynPortDriver.h>
#include <asynOctetSyncIO.h>
#include <epicsEvent.h>
#include <epicsThread.h>
#include <epicsTime.h>
#include <epicsExport.h>
#include <errlog.h>
#include <iocsh.h>
#include "devScalerAsyn.h"
#define MAX_CHANNELS 8 //////////////////////////chang 4 to 8
#define timeOut 0.1
static const char *driverName= "ScalerCT08E"; // >- Scaler974 change to CT08E
class ScalerCT08E:public asynPortDriver
public:
ScalerCT08E(const char *portName, const char *serialPort, int serialAddr, int poll);
virtual asynStatus writeInt32(asynUser *pasynUser, epicsInt32 value);
virtual asynStatus readInt32Array(asynUser *pasynUser,epicsInt32 *value, size_t nElements, size_t *nIn);
virtual void report(FILE *fp, int details);
void eventThread();
private:
int scalerReset;
int scalerChannels;
int scalerRead;
int scalerReadSingle;
int scalerPreset;
int scalerArm;
int scalerDone;
double polltime;
epicsEventId eventId;
asynUser *pasynUserScaler;
asynStatus sendCommand(const char *command, char *statusString, size_t maxStatusLen, size_t *statusLen);
asynStatus sendCommand(const char *command, char *statusString, size_t maxStatusLen, size_t *statusLen,
char *response, size_t maxResponseLen, size_t *responseLen);
static void eventThreadC(void *pPvt)
ScalerCT08E *pScalerCT08E = (ScalerCT08E *)pPvt;
pScalerCT08E->eventThread();
ScalerCT08E::ScalerCT08E(const char *portName, const char *serialPort, int serialAddr, int poll)
:asynPortDriver(portName, MAX_CHANNELS, 7,
asynInt32Mask | asynInt32ArrayMask | asynDrvUserMask,
asynInt32Mask,
/* Should also be ASYN_CANBLOCK, but device support does not work with asynchronous devices */
ASYN_MULTIDEVICE,1,0,0)
int i;
asynStatus status;
static const char *functionName="ScalerCT08E";
if (poll==0) poll=100;
this->polltime=poll / 1000.;
this->eventId = epicsEventCreate(epicsEventEmpty);
status = pasynOctetSyncIO->connect(serialPort, serialAddr, &this->pasynUserScaler, NULL);
if (status != asynSuccess) {
asynPrint(this->pasynUserSelf, ASYN_TRACE_ERROR,
"%s:%s: error connecting to port %s address %d\n",
driverName, functionName, serialPort, serialAddr);
return;
createParam(SCALER_RESET_COMMAND_STRING, asynParamInt32, &this->scalerReset);
createParam(SCALER_CHANNELS_COMMAND_STRING, asynParamInt32, &this->scalerChannels);
createParam(SCALER_READ_COMMAND_STRING, asynParamInt32Array,&this->scalerRead);
createParam(SCALER_READ_SINGLE_COMMAND_STRING, asynParamInt32, &this->scalerReadSingle);
createParam(SCALER_PRESET_COMMAND_STRING, asynParamInt32, &this->scalerPreset);
createParam(SCALER_ARM_COMMAND_STRING, asynParamInt32, &this->scalerArm);
createParam(SCALER_DONE_COMMAND_STRING, asynParamInt32, &this->scalerDone);
setIntegerParam(scalerChannels, MAX_CHANNELS);
setIntegerParam(scalerDone, 1);
for (i=0; i<MAX_CHANNELS; i++) setIntegerParam(i, scalerReadSingle, 0);
epicsThreadCreate("ScalerCT08E",
epicsThreadPriorityMedium,
epicsThreadGetStackSize(epicsThreadStackMedium),
(EPICSTHREADFUNC)eventThreadC,this);
asynStatus ScalerCT08E::sendCommand(const char *command, char *statusString, size_t maxStatusLen, size_t *statusLen)
return sendCommand(command, statusString, maxStatusLen, statusLen, NULL, 0, NULL);
asynStatus ScalerCT08E::sendCommand(const char *command, char *statusString, size_t maxStatusLen, size_t *statusLen,
size_t nWrite;
asynStatus status;
double timeout = 1.0;
int eomReason;
static const char *functionName = "sendCommand";
if (response != NULL) {
status = pasynOctetSyncIO->writeRead(this->pasynUserScaler, command, strlen(command),
response, maxResponseLen, timeout, &nWrite, responseLen, &eomReason);
if (status != asynSuccess) goto done;
status = pasynOctetSyncIO->read(this->pasynUserScaler,
statusString, maxStatusLen, timeout, statusLen, &eomReason);
} else {
statusString, maxStatusLen, timeout, &nWrite, statusLen, &eomReason);
done:
"%s:%s: writing command %s, error=%s\n",
driverName, functionName, command, this->pasynUserScaler->errorMessage);
return(status);
asynStatus ScalerCT08E::writeInt32(asynUser *pasynUser, epicsInt32 value)
int function = pasynUser->reason;
char response[512]; //increase the number 256 ->512
size_t responseLen;
asynStatus status = asynSuccess;
static const char *functionName="writeInt32";
setIntegerParam(function, value);
if(function==this->scalerReset)
this->sendCommand("STOP", response, sizeof(response), &responseLen);
this->sendCommand("CLAL", response, sizeof(response), &responseLen); // i think here is the command, so I changed CLEAR_ALL to CLAL
asynPrint(pasynUser, ASYN_TRACE_FLOW, "%s:%s scalerReset\n",driverName, functionName);
else if(function==this->scalerArm)
if(value !=0)
/* Start counting */
this->sendCommand("STRT", response, sizeof(response), &responseLen); // START TO STRT
setIntegerParam(scalerDone, 0);
epicsEventSignal(this->eventId);
else
/* Stop counting */
status = this->sendCommand("STOP", response, sizeof(response), &responseLen);
asynPrint(pasynUser, ASYN_TRACE_FLOW, "%s:%s scalerArm=%d\n", driverName, functionName,value);
else if(function==this->scalerPreset) // modified a lot
int m; // m means millsecond
char newstr[40];
sprintf(newstr,"TPR%d",m);
this->sendCommand(newstr, response, sizeof(response), &responseLen);
asynPrint(pasynUser, ASYN_TRACE_FLOW, "%s;%s scalerPreset channel", driverName, functionName);
// setIntegerParam(scalerDone, 0);
int m,n;
char newstr[20];
n=(int)log10(double(value));
m=(int)(value/pow(10.0,n));
sprintf(newstr, "SET_COUNT_PRESET %d,%d", m, n);
else
asynPrint(pasynUser,ASYN_TRACE_ERROR,"%s:%s got illegal function %d\n", driverName, functionName, function);
callParamCallbacks();
return(status);
asynStatus ScalerCT08E::readInt32Array(asynUser *pasynUser, epicsInt32 *value, size_t maxChannel, size_t *nIn)
static const char *functionName="readInt32Array";
int temp;
int i;
if (maxChannel > MAX_CHANNELS) maxChannel = MAX_CHANNELS;
*nIn = maxChannel;
if (function==scalerRead)
for (i=0; i<(int)maxChannel; i++)
getIntegerParam(i, scalerReadSingle, &temp);
value[i] = temp;
asynPrint(pasynUser, ASYN_TRACEIO_DRIVER,
"%s:%s: value=%d %d %d %d\n",
driverName, functionName, value[0], value[1], value[2], value[3]);
} else {
return(asynError);
return(asynSuccess);
void ScalerCT08E::report(FILE *fp, int details)
asynPortDriver::report(fp, details);
void ScalerCT08E::eventThread()
int done, presetCount;
char response[100], statusString[20];
size_t responseLen, statusLen;
int counts[MAX_CHANNELS];
int i;
asynStatus status;
static const char *functionName="eventThread";
while(1) // SHOW_COUNTS need to change a lot,later
epicsEventWait(this->eventId);
while(1)
status = this->sendCommand("RDAL", statusString, sizeof(statusString), &statusLen,
sscanf(response, "%d %d %d %d %d %d %d %d %d",
&counts[0], &counts[1], &counts[2], &counts[3], &counts[4], &counts[5], &counts[6], &counts[7], &counts[8]); //counts[8] was the timer
asynPrint(this->pasynUserSelf, ASYN_TRACEIO_DRIVER,
"%s:%s status=%d, counts=%d %d %d %d %d %d %d %d %d\n",
driverName, functionName, status, counts[0], counts[1], counts[2], counts[3], counts[4], counts[5], counts[6], counts[7], counts[8] ); // I think here should be changed, I added "%d".
this->lock();
/* Get value of done in case scaler was stopped by scalerArm(0) */
getIntegerParam(scalerDone, &done);
getIntegerParam(scalerPreset, &presetCount);
if (!done && (counts[0] >= presetCount)) done = 1;
setIntegerParam(scalerDone, done);
for (i=0; i<MAX_CHANNELS; i++) {
setIntegerParam(i, scalerReadSingle, counts[i]);
callParamCallbacks(i, i);
this->unlock();
if (done) break;
epicsThreadSleep(this->polltime);
extern "C" int initScalerCT08E(const char *portName, const char *serialPort, int serialAddr, int poll)
new ScalerCT08E(portName, serialPort, serialAddr, poll);
/* iocsh function */
static const iocshArg initArg0 = {"Port Name", iocshArgString};
static const iocshArg initArg1 = {"Scaler Port", iocshArgString};
static const iocshArg initArg2 = {"GPIB address", iocshArgString};
static const iocshArg initArg3 = {"Poll", iocshArgInt};
static const iocshArg *const initArgs[] = {&initArg0,
&initArg1,
&initArg2,
&initArg3
static const iocshFuncDef initFuncDef = {"initScalerCT08E",4, initArgs}; // 4 means 4 channel? I have 8 channel, maybe not ,just the number of args.
static void initCallFunc(const iocshArgBuf *args)
initScalerCT08E(args[0].sval, args[1].sval, args[2].ival, args[3].ival); //init command
void ScalerCT08ERegister(void)
iocshRegister(&initFuncDef,initCallFunc);
extern "C" {
epicsExportRegistrar(ScalerCT08ERegister);
The information of start IOC :
Successfully locked memory using mlockAll
# Linux startup script
# For devIocStats
#epicsEnvSet("ENGINEER","engineer")
#epicsEnvSet("LOCATION","location")
#epicsEnvSet("GROUP","group")
< envPaths
epicsEnvSet("ARCH","linux-x86_64")
epicsEnvSet("IOC","iocLinux")
epicsEnvSet("TOP","/opt/synApps_5_8/support/xxx-5-8-3")
epicsEnvSet("SUPPORT","/opt/synApps_5_8/support")
epicsEnvSet("EPICS_BASE","/opt/base")
epicsEnvSet("ALIVE","/opt/synApps_5_8/support/alive-1-0")
epicsEnvSet("ALLEN_BRADLEY","/opt/synApps_5_8/support/allenBradley-2-3")
epicsEnvSet("AREA_DETECTOR","/opt/synApps_5_8/support/areaDetector-R2-0")
epicsEnvSet("ADCORE","/opt/synApps_5_8/support/areaDetector-R2-0/ADCore-R2-2")
epicsEnvSet("ADBINARIES","/opt/synApps_5_8/support/areaDetector-R2-0/ADBinaries-R2-2")
epicsEnvSet("ASYN","/opt/synApps_5_8/support/asyn-4-32")
epicsEnvSet("AUTOSAVE","/opt/synApps_5_8/support/autosave-5-6-1")
epicsEnvSet("BUSY","/opt/synApps_5_8/support/busy-1-6-1")
epicsEnvSet("CALC","/opt/synApps_5_8/support/calc-3-4-2-1")
epicsEnvSet("CAMAC","/opt/synApps_5_8/support/camac-2-7")
epicsEnvSet("CAPUTRECORDER","/opt/synApps_5_8/support/caputRecorder-1-6")
epicsEnvSet("DAC128V","/opt/synApps_5_8/support/dac128V-2-8")
epicsEnvSet("DELAYGEN","/opt/synApps_5_8/support/delaygen-1-1-1")
epicsEnvSet("DEVIOCSTATS","/opt/synApps_5_8/support/devIocStats-3-1-13")
epicsEnvSet("DXP","/opt/synApps_5_8/support/dxp-3-4")
epicsEnvSet("IP","/opt/synApps_5_8/support/ip-2-17")
epicsEnvSet("IP330","/opt/synApps_5_8/support/ip330-2-8")
epicsEnvSet("IPAC","/opt/synApps_5_8/support/ipac-2-13")
epicsEnvSet("IPUNIDIG","/opt/synApps_5_8/support/ipUnidig-2-10")
epicsEnvSet("LOVE","/opt/synApps_5_8/support/love-3-2-5")
epicsEnvSet("MCA","/opt/synApps_5_8/support/mca-7-6")
epicsEnvSet("MEASCOMP","/opt/synApps_5_8/support/measComp-1-1")
epicsEnvSet("MODBUS","/opt/synApps_5_8/support/modbus-2-7")
epicsEnvSet("MOTOR","/opt/synApps_5_8/support/motor-6-9")
epicsEnvSet("OPTICS","/opt/synApps_5_8/support/optics-2-9-3")
epicsEnvSet("QUADEM","/opt/synApps_5_8/support/quadEM-5-0")
epicsEnvSet("SNCSEQ","/opt/synApps_5_8/support/seq-2-2-3")
epicsEnvSet("SOFTGLUE","/opt/synApps_5_8/support/softGlue-2-4-3")
epicsEnvSet("SSCAN","/opt/synApps_5_8/support/sscan-2-10-1")
epicsEnvSet("STD","/opt/synApps_5_8/support/std-3-4")
epicsEnvSet("STREAM","/opt/synApps_5_8/support/stream-2-6a")
epicsEnvSet("VAC","/opt/synApps_5_8/support/vac-1-5-1")
epicsEnvSet("VME","/opt/synApps_5_8/support/vme-2-8-2")
epicsEnvSet("XXX","/opt/synApps_5_8/support/xxx-5-8-3")
epicsEnvSet(("STREAM_PROTOCOL_PATH","/opt/synApps_5_8/support/xxx-5-8-3")
# save_restore.cmd needs the full path to the startup directory, which
# envPaths currently does not provide
epicsEnvSet(STARTUP,/opt/synApps_5_8/support/xxx-5-8-3/iocBoot/iocLinux)
# Increase size of buffer for error logging from default 1256
errlogInit(20000)
# Specify largest array CA will transport
# Note for N doubles, need N*8 bytes+some overhead
epicsEnvSet EPICS_CA_MAX_ARRAY_BYTES 64010
# Tell EPICS all about the record types, device-support modules, drivers,
# etc. in the software we just loaded (xxx.munch)
dbLoadDatabase("../../dbd/iocxxxLinux.dbd")
iocxxxLinux_registerRecordDeviceDriver(pdbbase)
### save_restore setup
#< save_restore.cmd
# Access Security
dbLoadRecords("/opt/synApps_5_8/support/xxx-5-8-3/xxxApp/Db/Security_Control.db","P=xxx:")
asSetFilename("/opt/synApps_5_8/support/xxx-5-8-3/iocBoot/accessSecurity.acf")
asSetSubstitutions("P=xxx:")
# trap listener
#dbLoadRecords("$(CAPUTRECORDER)/caputRecorderApp/Db/caputPoster.db","P=xxx:,N=300")
#doAfterIocInit("registerCaputRecorderTrapListener('xxx:caputRecorderCommand')")
# GUI database
#dbLoadRecords("$(CAPUTRECORDER)/caputRecorderApp/Db/caputRecorder.db","P=xxx:,N=300")
# soft scaler for testing
#< softScaler.cmd
# user-assignable ramp/tweak
###dbLoadRecords("$(STD)/stdApp/Db/ramp_tweak.db","P=xxx:,Q=rt1")
drvAsynIPPortConfigure("CT08E", "192.168.1.123:7777", 0, 0, 0)
asynOctetSetInputEos("CT08E",0,"\r\n")
asynOctetSetOutputEos("CT08E",0,"\r\n")
asynSetTraceIOMask("CTStarting iocInit
08E",0,0x2)
asynSetTraceMask("CT08E",0,255)
asynOctetConnect("CT08E","CT08E")
#asynOctetWriteRead("CT08E","INIT")
#asynSetTraceIOMask("CT08E",-1,0x9)
initScalerCT08E("serialCT08E","CT08E",0,100) ####
### Stuff for user programming ###
###< calc.cmd
# 4-step measurement
#dbLoadRecords("$(STD)/stdApp/Db/4step.db", "P=xxx:,Q=4step:")
# Miscellaneous PV's, such as burtResult
dbLoadRecords("/opt/synApps_5_8/support/std-3-4/stdApp/Db/misc.db","P=xxx:")
dbLoadRecords("/opt/synApps_5_8/support/std-3-4/stdApp/Db/scaler.db","P=xxx:,S=scaler1,OUT=@asyn(serialCT08E 0 0),DTYP=Asyn Scaler,FREQ=10,TP=1,TP1=0.5,PR1=1,CONT=1")
iocInit
## EPICS R3.15.2 $Date: Thu 2015-05-14 14:09:28 +0200$
## EPICS Base built Oct 16 2016
# Report states of database CA links
dbcar(*,1)
CA links in all records
Total 0 CA links; 0 connected, 0 not connected.
0 can't read, 0 can't write. (0 disconnects, 0 writes prohibited)
I used scaler.opi.
After I pressed the "Count" button, the output of IOC:
epics> 2017/09/21 17:40:18.298 CT08E asynManager::queueLockPort locking port
2017/09/21 17:40:18.298 CT08E asynManager::queueLockPort created queueLockPortPvt=0x7f6a2c047880
2017/09/21 17:40:18.298 CT08E asynManager::queueLockPort created queueLockPortPvt=0x7f6a2c047880, event=0x7f6a2c0478a0, mutex=0x7f6a2c047950
2017/09/21 17:40:18.298 CT08E asynManager::queueLockPort taking mutex 0x7f6a2c047950
2017/09/21 17:40:18.298 CT08E asynManager::queueLockPort queueing request
2017/09/21 17:40:18.298 CT08E addr -1 queueRequest priority 0 not lockHolder
2017/09/21 17:40:18.298 CT08E asynManager::queueLockPort waiting for event
2017/09/21 17:40:18.298 asynManager::portThread port=CT08E callback
2017/09/21 17:40:18.298 CT08E asynManager::queueLockPortCallback signaling begin event
2017/09/21 17:40:18.298 CT08E asynManager::queueLockPortCallback waiting for mutex from queueUnlockPort
2017/09/21 17:40:18.298 CT08E asynManager::queueLockPort got event from callback
2017/09/21 17:40:18.298 CT08E flush
2017/09/21 17:40:18.298 192.168.1.123:7777 flush
2017/09/21 17:40:18.298 192.168.1.123:7777 write.
2017/09/21 17:40:18.298 192.168.1.123:7777 write 6
STOP\r\n
2017/09/21 17:40:18.298 wrote 6 to 192.168.1.123:7777, return asynSuccess.
2017/09/21 17:40:18.298 CT08E wrote
STOP\r\n
2017/09/21 17:40:18.298 asynOctetSyncIO wrote:
STOP
2017/09/21 17:40:18.298 192.168.1.123:7777 read.
2017/09/21 17:40:19.298 CT08E queueUnlockPort
2017/09/21 17:40:19.298 CT08E asynManager::queueUnlockPort waiting for event
2017/09/21 17:40:19.298 CT08E queueUnlockPort unlock mutex 0x7f6a2c047950 complete.
2017/09/21 17:40:19.298 ScalerCT08E:sendCommand: writing command STOP, error=192.168.1.123:7777 timeout: Resource temporarily unavailable
2017/09/21 17:40:19.298 CT08E asynManager::queueLockPort locking port
2017/09/21 17:40:19.298 CT08E asynManager::queueLockPort taking mutex 0x7f6a2c047950
2017/09/21 17:40:19.298 CT08E asynManager::queueLockPort queueing request
2017/09/21 17:40:19.298 CT08E addr -1 queueRequest priority 0 not lockHolder
2017/09/21 17:40:19.298 CT08E asynManager::queueLockPort waiting for event
2017/09/21 17:40:19.298 asynManager::portThread port=CT08E callback
2017/09/21 17:40:19.298 CT08E asynManager::queueLockPortCallback signaling begin event
2017/09/21 17:40:19.298 CT08E asynManager::queueLockPortCallback waiting for mutex from queueUnlockPort
2017/09/21 17:40:19.298 CT08E asynManager::queueLockPort got event from callback
2017/09/21 17:40:19.298 CT08E flush
2017/09/21 17:40:19.298 192.168.1.123:7777 flush
2017/09/21 17:40:19.298 192.168.1.123:7777 write.
2017/09/21 17:40:19.298 192.168.1.123:7777 write 6
CLAL\r\n
2017/09/21 17:40:19.298 wrote 6 to 192.168.1.123:7777, return asynSuccess.
2017/09/21 17:40:19.298 CT08E wrote
CLAL\r\n
2017/09/21 17:40:19.298 asynOctetSyncIO wrote:
CLAL
2017/09/21 17:40:19.298 192.168.1.123:7777 read.
2017/09/21 17:40:20.299 CT08E queueUnlockPort
2017/09/21 17:40:20.299 CT08E asynManager::queueUnlockPort waiting for event
2017/09/21 17:40:20.299 CT08E queueUnlockPort unlock mutex 0x7f6a2c047950 complete.
2017/09/21 17:40:20.299 ScalerCT08E:sendCommand: writing command CLAL, error=192.168.1.123:7777 timeout: Resource temporarily unavailable
2017/09/21 17:40:20.299 CT08E asynManager::queueLockPort locking port
2017/09/21 17:40:20.299 CT08E asynManager::queueLockPort taking mutex 0x7f6a2c047950
2017/09/21 17:40:20.299 CT08E asynManager::queueLockPort queueing request
2017/09/21 17:40:20.299 CT08E addr -1 queueRequest priority 0 not lockHolder
2017/09/21 17:40:20.299 CT08E asynManager::queueLockPort waiting for event
2017/09/21 17:40:20.299 asynManager::portThread port=CT08E callback
2017/09/21 17:40:20.299 CT08E asynManager::queueLockPortCallback signaling begin event
2017/09/21 17:40:20.299 CT08E asynManager::queueLockPortCallback waiting for mutex from queueUnlockPort
2017/09/21 17:40:20.299 CT08E asynManager::queueLockPort got event from callback
2017/09/21 17:40:20.299 CT08E flush
2017/09/21 17:40:20.299 192.168.1.123:7777 flush
2017/09/21 17:40:20.299 192.168.1.123:7777 write.
2017/09/21 17:40:20.299 192.168.1.123:7777 write 6
TPR0\r\n
2017/09/21 17:40:20.299 wrote 6 to 192.168.1.123:7777, return asynSuccess.
2017/09/21 17:40:20.299 CT08E wrote
TPR0\r\n
2017/09/21 17:40:20.299 asynOctetSyncIO wrote:
TPR0
2017/09/21 17:40:20.299 192.168.1.123:7777 read.
2017/09/21 17:40:21.299 CT08E queueUnlockPort
2017/09/21 17:40:21.299 CT08E asynManager::queueUnlockPort waiting for event
2017/09/21 17:40:21.299 CT08E queueUnlockPort unlock mutex 0x7f6a2c047950 complete.
2017/09/21 17:40:21.299 ScalerCT08E:sendCommand: writing command TPR0, error=192.168.1.123:7777 timeout: Resource temporarily unavailable
2017/09/21 17:40:21.299 CT08E asynManager::queueLockPort locking port
2017/09/21 17:40:21.299 CT08E asynManager::queueLockPort taking mutex 0x7f6a2c047950
2017/09/21 17:40:21.299 CT08E asynManager::queueLockPort queueing request
2017/09/21 17:40:21.299 CT08E addr -1 queueRequest priority 0 not lockHolder
2017/09/21 17:40:21.299 CT08E asynManager::queueLockPort waiting for event
2017/09/21 17:40:21.299 asynManager::portThread port=CT08E callback
2017/09/21 17:40:21.299 CT08E asynManager::queueLockPortCallback signaling begin event
2017/09/21 17:40:21.299 CT08E asynManager::queueLockPortCallback waiting for mutex from queueUnlockPort
2017/09/21 17:40:21.299 CT08E asynManager::queueLockPort got event from callback
2017/09/21 17:40:21.299 CT08E flush
2017/09/21 17:40:21.299 192.168.1.123:7777 flush
2017/09/21 17:40:21.299 192.168.1.123:7777 write.
2017/09/21 17:40:21.299 192.168.1.123:7777 write 6
STRT\r\n
2017/09/21 17:40:21.299 wrote 6 to 192.168.1.123:7777, return asynSuccess.
2017/09/21 17:40:21.299 CT08E wrote
STRT\r\n
2017/09/21 17:40:21.299 asynOctetSyncIO wrote:
STRT
2017/09/21 17:40:21.299 192.168.1.123:7777 read.
2017/09/21 17:40:22.299 CT08E queueUnlockPort
2017/09/21 17:40:22.299 CT08E asynManager::queueUnlockPort waiting for event
2017/09/21 17:40:22.299 CT08E queueUnlockPort unlock mutex 0x7f6a2c047950 complete.
2017/09/21 17:40:22.299 ScalerCT08E:sendCommand: writing command STRT, error=192.168.1.123:7777 timeout: Resource temporarily unavailable
2017/09/21 17:40:22.299 CT08E asynManager::queueLockPort locking port
2017/09/21 17:40:22.299 CT08E asynManager::queueLockPort created queueLockPortPvt=0x7f6a300008c0
2017/09/21 17:40:22.299 CT08E asynManager::queueLockPort created queueLockPortPvt=0x7f6a300008c0, event=0x7f6a300008e0, mutex=0x7f6a30000990
2017/09/21 17:40:22.299 CT08E asynManager::queueLockPort taking mutex 0x7f6a30000990
2017/09/21 17:40:22.299 CT08E asynManager::queueLockPort queueing request
2017/09/21 17:40:22.299 CT08E addr -1 queueRequest priority 0 not lockHolder
2017/09/21 17:40:22.299 CT08E asynManager::queueLockPort waiting for event
2017/09/21 17:40:22.299 asynManager::portThread port=CT08E callback
2017/09/21 17:40:22.299 CT08E asynManager::queueLockPortCallback signaling begin event
2017/09/21 17:40:22.299 CT08E asynManager::queueLockPortCallback waiting for mutex from queueUnlockPort
2017/09/21 17:40:22.299 CT08E asynManager::queueLockPort got event from callback
2017/09/21 17:40:22.299 CT08E flush
2017/09/21 17:40:22.299 192.168.1.123:7777 flush
2017/09/21 17:40:22.299 192.168.1.123:7777 write.
2017/09/21 17:40:22.299 192.168.1.123:7777 write 6
RDAL\r\n
2017/09/21 17:40:22.300 wrote 6 to 192.168.1.123:7777, return asynSuccess.
2017/09/21 17:40:22.300 CT08E wrote
RDAL\r\n
2017/09/21 17:40:22.300 asynOctetSyncIO wrote:
RDAL
2017/09/21 17:40:22.300 192.168.1.123:7777 read.
2017/09/21 17:40:22.303 192.168.1.123:7777 read 100
0000000004 0000000000 0000000000 0000000000 0000000000 0000000000 0000000000 000
2017/09/21 17:40:22.303 CT08E read
2017/09/21 17:40:22.303 asynOctetSyncIO read:
2017/09/21 17:40:22.303 CT08E queueUnlockPort
2017/09/21 17:40:22.303 CT08E asynManager::queueUnlockPort waiting for event
2017/09/21 17:40:22.303 CT08E queueUnlockPort unlock mutex 0x7f6a30000990 complete.
2017/09/21 17:40:22.303 CT08E asynManager::queueLockPort locking port
2017/09/21 17:40:22.303 CT08E asynManager::queueLockPort taking mutex 0x7f6a30000990
2017/09/21 17:40:22.303 CT08E asynManager::queueLockPort queueing request
2017/09/21 17:40:22.303 CT08E addr -1 queueRequest priority 0 not lockHolder
2017/09/21 17:40:22.303 CT08E asynManager::queueLockPort waiting for event
2017/09/21 17:40:22.303 asynManager::portThread port=CT08E callback
2017/09/21 17:40:22.303 CT08E asynManager::queueLockPortCallback signaling begin event
2017/09/21 17:40:22.303 CT08E asynManager::queueLockPortCallback waiting for mutex from queueUnlockPort
2017/09/21 17:40:22.303 CT08E asynManager::queueLockPort got event from callback
2017/09/21 17:40:22.303 192.168.1.123:7777 read.
2017/09/21 17:40:23.303 CT08E queueUnlockPort
2017/09/21 17:40:23.303 CT08E asynManager::queueUnlockPort waiting for event
2017/09/21 17:40:23.303 CT08E queueUnlockPort unlock mutex 0x7f6a30000990 complete.
2017/09/21 17:40:23.303 ScalerCT08E:sendCommand: writing command RDAL, error=192.168.1.123:7777 timeout: Resource temporarily unavailable
2017/09/21 17:40:23.403 CT08E asynManager::queueLockPort locking port
2017/09/21 17:40:23.403 CT08E asynManager::queueLockPort taking mutex 0x7f6a30000990
2017/09/21 17:40:23.403 CT08E asynManager::queueLockPort queueing request
2017/09/21 17:40:23.403 CT08E addr -1 queueRequest priority 0 not lockHolder
2017/09/21 17:40:23.403 CT08E asynManager::queueLockPort waiting for event
2017/09/21 17:40:23.403 asynManager::portThread port=CT08E callback
2017/09/21 17:40:23.403 CT08E asynManager::queueLockPortCallback signaling begin event
2017/09/21 17:40:23.403 CT08E asynManager::queueLockPortCallback waiting for mutex from queueUnlockPort
2017/09/21 17:40:23.403 CT08E asynManager::queueLockPort got event from callback
2017/09/21 17:40:23.403 CT08E flush
2017/09/21 17:40:23.403 192.168.1.123:7777 flush
2017/09/21 17:40:23.403 192.168.1.123:7777 write.
2017/09/21 17:40:23.403 192.168.1.123:7777 write 6
RDAL\r\n
2017/09/21 17:40:23.403 wrote 6 to 192.168.1.123:7777, return asynSuccess.
2017/09/21 17:40:23.403 CT08E wrote
RDAL\r\n
2017/09/21 17:40:23.403 asynOctetSyncIO wrote:
RDAL
2017/09/21 17:40:23.403 192.168.1.123:7777 read.
2017/09/21 17:40:23.407 192.168.1.123:7777 read 100
0000000007 0000000000 0000000000 0000000000 0000000000 0000000000 0000000000 000
2017/09/21 17:40:23.407 CT08E read
2017/09/21 17:40:23.407 asynOctetSyncIO read:
2017/09/21 17:40:23.407 CT08E queueUnlockPort
2017/09/21 17:40:23.407 CT08E asynManager::queueUnlockPort waiting for event
2017/09/21 17:40:23.407 CT08E queueUnlockPort unlock mutex 0x7f6a30000990 complete.
2017/09/21 17:40:23.407 CT08E asynManager::queueLockPort locking port
2017/09/21 17:40:23.407 CT08E asynManager::queueLockPort taking mutex 0x7f6a30000990
2017/09/21 17:40:23.407 CT08E asynManager::queueLockPort queueing request
2017/09/21 17:40:23.407 CT08E addr -1 queueRequest priority 0 not lockHolder
2017/09/21 17:40:23.407 CT08E asynManager::queueLockPort waiting for event
2017/09/21 17:40:23.407 asynManager::portThread port=CT08E callback
2017/09/21 17:40:23.407 CT08E asynManager::queueLockPortCallback signaling begin event
2017/09/21 17:40:23.407 CT08E asynManager::queueLockPortCallback waiting for mutex from queueUnlockPort
- RE: new Scaler driver Mark Rivers
Re: Ideas / Suggestions for the future of VME-CPU Operating Systems Goetz Pfeiffer
Re: dbVerify removed from EPICS 3.16 Andrew Johnson
<2017>
Re: Ideas / Suggestions for the future of VME-CPU Operating Ambrosch Kristian (PSI)
<2017>
