Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: Re: dbVerify removed from EPICS 3.16
To: michael.abbott@diamond.ac.uk, anj@aps.anl.gov, tech-talk@aps.anl.gov
Date: Wed, 20 Sep 2017 12:09:54 -0500
On 09/20/2017 01:43 AM, michael.abbott@diamond.ac.uk wrote:
> Hmm.  An external linting problem doesn't fit my application very well.
True.  I've used this as a step between build (msi expansion) and load.
> How do you validate field assignments in your application, Michael?  I need to be able to do something like the following:
So far only link fields (where I usually typo).  Field types are known,
so this could be done for other fields.  However, it wouldn't give quite
the same assurance as it would be different code (pypdb doesn't depend
on Base).  So I'm not sure if this would be good enough for you.
>>>> a = records.ao('TEST')
>>>> a.DRVL = 'wrong'
> AssertionError: Can't write "test" to field DRVL: not a number
>>>> a.DRVL = 123
>>>> a.SCAN = 'wrong'
> AssertionError: Can't write "wrong" to field SCAN: Not a valid menu choice
>>>> a.SCAN = '.1 second'
> From: Michael Davidsaver [mailto:mdavidsaver@gmail.com]
>> If you're interested in static validation of db/dbd files, you might
>> have a look at my 'dbdlint' script.  This can either validate individual
>> files for basic syntax (--partial), or a full database w/ recordtype
>> defs (--full).
>> This includes a handy (to me) feature to detect unintentional "external"
>> links (aka typos).
>>> $ cat test.db
>>> #: external("other.VAL")
>>> record(longin, "target") {
>>>     field(INP, "other")
>>> record(longin, "ok") {
>>>     field(INP, "targt") # oops
>>> $ ./dbdlint -F -Wall /path/to/base/dbd/softIoc.dbd test.db
>>> WARNING test.db:8 ext-link - DB/CA Link to outside PV 'targt.VAL'
>> https://github.com/epicsdeb/pypdb/blob/master/documentation/dbdlint.rst
>> https://github.com/epicsdeb/pypdb/blob/master/dbdlint.1.txt
>> On 09/19/2017 01:00 PM, Andrew Johnson wrote:
>>> Hi Michael,
>>> On 09/19/2017 04:34 AM, michael.abbott@diamond.ac.uk wrote:
>>>> I have just discovered that the dbVerify function has been removed from
>>>> EPICS 3.16.  I use the functionality provided by this function to
>>>> validate databases as they are statically constructed (in iocbuilder
>>>> and epicsdbbuilder).  At present DLS is still using EPICS 3.14, so I am
>>>> only learning about this from external reports.
dbVerify removed from EPICS 3.16 michael.abbott
Re: dbVerify removed from EPICS 3.16 Andrew Johnson
Re: dbVerify removed from EPICS 3.16 Michael Davidsaver
RE: dbVerify removed from EPICS 3.16 michael.abbott
Prev: Re: Ideas / Suggestions for the future of VME-CPU Operating Systems Michael Davidsaver
Next: Re: PointGrey Firmware Mark Engbretson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Prev: RE: dbVerify removed from EPICS 3.16 michael.abbott
Next: RE: dbVerify removed from EPICS 3.16 michael.abbott
ANJ, 20 Sep 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
