Dear Ralph, Michael, Mark, Kay, Dirk, et al. FIrst of all thank you again for all recommendations. I am going to try to explain which configuration does work and which doesn't.[dsanz@localhost ~]$ export EPICS_CA_ADDR_LIST="10.0.2.255" [dsanz@localhost ~]$ caget dsanzHost:ai1 Warning: Duplicate EPICS CA Address list entry "10.0.2.255:5064" discarded Channel connect timed out: 'dsanzHost:ai1' not found. [dsanz@localhost ~]$ caget pcounter Warning: Duplicate EPICS CA Address list entry "10.0.2.255:5064" discarded Channel connect timed out: 'pcounter' not found. [dsanz@localhost ~]$ export EPICS_CA_ADDR_LIST="127.255.255.255" [dsanz@localhost ~]$ caget pcounter pcounter 0 [dsanz@localhost ~]$ caget dsanzHost:ai1 dsanzHost:ai1 6 Mark, regarding EPICS_CA_AUTO_ADDR_LIST set to NO, I have try without configuring it, and it works, I put both YES or NO, and it works. I do not know if this should be work in this way or not... but it is absolutely the same, even if you put EPICS_CA_AUTO_ADDR_LIST="come to ICALPECS2017" :) Well, if 127.255.255.255 works, but 10.0.2.255 doesn't, I thought to configure the 2 IOCs with EPICS_CAS_INTF_ADDR=10.0.5.15... and then I configure the client with EPICS_CA_ADDR_LIST=10.0.2.255 (broadcast IP address) but in this way it neither works. Then it looks, that is crucial the loopback interface for this configuration? Thank you very much to everybody, I hope this questions help other people too. Regards Diego 2017-09-14 21:00 GMT+02:00 Ralph Lange <[email protected]>:
ANJ, 21 Dec 2017 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
