1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: mbboDirect record and SHFT field
To: <[email protected]>
Date: Fri, 15 Sep 2017 11:04:30 +0200
On 13.09.2017 23:22, Rod Nussbaumer wrote:
In the record reference manual for 3-14 record reference manual, it says
"the SHFT value is set by device support and is not configurable by the
user". The information in the accompanying table supports this,
indicating in the 'DCT' field of the table 'NO' for the SHFT field of
the record type.
Maybe it should better say: "the SHFT value may overwritten by device support". It all depends on what the device support does. I regularly set SHFT for several different device supports, including "Raw Soft Channel".
Dirk
mbboDirect record and SHFT field Rod Nussbaumer
Prev: triggerPV in DisplayBuilder Amien Crombie
Next: Re: mbboDirect record and SHFT field Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: RE: mbboDirect record and SHFT field Mark Rivers
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
