Dear guys, Again, thank you for your support. Still the problem persists. The idea of using "lo" interface is for testing purposes, but anyway, now I am using other ip:enp0s3: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 10.0.2.15 netmask 255.255.255.0 broadcast 10.0.2.255 epicsEnvSet("EPICS_CA_ADDR_LIST","10.0.2.15") ## Load record instances # dbLoadTemplate "db/userHost.substitutions" dbLoadRecords "db/devsimulation.db", "user=dsanzHost" ## Set this to see messages from mySub #var mySubDebug 1 ## Run this to trace the stages of iocInit #traceIocInit cd "/home/dsanz/Developments/edsTemplate-epics/iocBoot/ioctest" iocInit Starting iocInit ############################################################################ ## EPICS R3.14.12.6 ## EPICS Base built Jan 31 2017 ############################################################################ iocRun: All initialization complete ## Start any sequence programs #seq sncExample, "user=dsanzHost" epics> ...... epicsEnvSet("EPICS_CA_ADDR_LIST","10.0.2.15") ## Load record instances dbLoadTemplate "db/userHost.substitutions" dbLoadRecords "db/dbSubExample.db", "user=dsanzHost" ## Set this to see messages from mySub #var mySubDebug 1 ## Run this to trace the stages of iocInit #traceIocInit cd "/home/dsanz/Developments/checkEpics/iocBoot/iocthis" iocInit Starting iocInit ############################################################################ ## EPICS R3.14.12.6 ## EPICS Base built Jan 31 2017 ############################################################################ cas warning: Configured TCP port was unavailable. cas warning: Using dynamically assigned TCP port 37633, cas warning: but now two or more servers share the same UDP port. cas warning: Depending on your IP kernel this server may not be cas warning: reachable with UDP unicast (a host's IP in EPICS_CA_ADDR_LIST) iocRun: All initialization complete ## Start any sequence programs #seq sncExample, "user=dsanzHost" epics> ..... [dsanz@localhost ~]$ set | grep EPICS_CA_ADDR EPICS_CA_ADDR_LIST=10.0.2.255 [dsanz@localhost ~]$ caget pcounter Warning: Duplicate EPICS CA Address list entry "10.0.2.255:5064" discarded Channel connect timed out: 'pcounter' not found. [dsanz@localhost ~]$ caget dsanzHost:ai1 Warning: Duplicate EPICS CA Address list entry "10.0.2.255:5064" discarded Channel connect timed out: 'dsanzHost:ai1' not found. 2017-09-13 17:45 GMT+02:00 Michael Davidsaver <[email protected]>: On 09/13/2017 10:05 AM, Diego Sanz wrote:
ANJ, 21 Dec 2017 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
