1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: Help creating motorR6-9 examples
From: Guilherme Jovanini Montagner <[email protected]>
Cc: "Ronald L. Sluiter" <[email protected]>, tech-talk <[email protected]>
Date: Thu, 14 Sep 2017 09:11:31 -0300 (BRT)
Oh, ok.
Thank you.
+55 19 2517.8911
+55 19 99806.9117
[email protected]
----- Mensagem original -----
De: "Mark Rivers" <[email protected]>
Para: "guilherme" <[email protected]>
Cc: "Ronald L. Sluiter" <[email protected]>, "tech-talk" <[email protected]>
Enviadas: Quinta-feira, 14 de setembro de 2017 9:04:25
Assunto: RE: Help creating motorR6-9 examples
> I couldn't find the "motors.template" file though. Where should it be located?
My apologies, there is not a consistent use of the file extensions ".template" and ".substitutions".  These are files that are loaded with the dbLoadTemplate IOC shell command.  The file extensions .template and .substitutions are both often used for the file that is loaded by this command.  These files in turn load lower-level database files, and for these the extensions .db and .template are both often used.
I was referring to the .substitutions files in motor/iocBoot/iocWithAsyn.
RE: Help creating motorR6-9 examples Mark Rivers
Re: Help creating motorR6-9 examples Guilherme Jovanini Montagner
Prev: RE: Help creating motorR6-9 examples Mark Rivers
Next: Re: Questions regarding CA protocol specification and phylosophy Diego Sanz
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Next: pre-ICALEPCS EPICS workshop reminder Timo Korhonen
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
