1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: How to use Archiver Appliance to archive PVs of only the latest period of time
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 14 Sep 2017 04:04:32 +0000
Hi Lin,
>> In order to save storage space, we just want to archive PVs of the latest one month.
You should be able to create a policy for these 5000 PV's with a partition granularity of a month. That is, in your policies.py file, your LTS (or MTS) can be something like
pb://localhost?name=LTS&rootFolder=${ARCHAPPL_LONG_TERM_FOLDER}&partitionGranularity=PARTITION_MONTH.
If you add PV's to the archiver using this policy, you should be able to store data in chunks of one month each.
>> the requirement may be adjusted to three or six months in future)
You could then delete the older data using a Python script. Or, if you decided to keep, let's say four months you could add a blackhole plugin after this plugin. For example,
LTS -> partitionGranularity=PARTITION_MONTH​&hold=5&gather=1 followed by a
Final -> 'blackhole://localhost'
would keep at least (5-1)=4 months data in your LTS.
For more details, please see http://slacmshankar.github.io/epicsarchiver_docs/api/edu/stanford/slac/archiverappliance/PlainPB/PlainPBStoragePlugin.html
Hope that helps.
Murali
Re: How to use Archiver Appliance to archive PVs of only the latest period of time Wang, Lin
Prev: mbboDirect record and SHFT field Rod Nussbaumer
Next: Re: Help creating motorR6-9 examples Guilherme Jovanini Montagner
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: How to use Archiver Appliance to archive PVs of only the latest period of time Wang, Lin
Next: Re: How to use Archiver Appliance to archive PVs of only the latest period of time Wang, Lin
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
