1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: RE: Help creating motorR6-9 examples
To: 'Guilherme Jovanini Montagner' <[email protected]>
Cc: "Ronald L. Sluiter" <[email protected]>, tech-talk <[email protected]>
Date: Wed, 13 Sep 2017 15:12:47 +0000
> Ok. I see. Do you know how can I get some information on how to do this?
There is online EPICS training here:
http://www.aps.anl.gov/epics/docs/APS2015.php
Under the Hardware Interfacing section there are 4 talks about motors.  I'm pretty sure what you need to know is explained there.
> I mean, is the driver complete and I just need to create the st.cmd file, or is there something else to it?
The driver should be complete, and all you need to do is to create the st.cmd and motors.template files.  However, if you need specialized functions in the controller that are not in the current EPICS driver then you might need to enhance the driver, but probably not.
> Also, where can I find information on writing this kind of file? What language is it written in?
The file is an IOC shell (iocsh) script.  The IOC shell is documented here:
http://www.aps.anl.gov/epics/base/R3-15/5-docs/AppDevGuide/IOCShell.html#x19-73300018
You can start an example IOC with simulated motors by doing the following:
cd devel/motor/iocBoot/iocWithAsyn/
../../bin/linux-x86_64/WithAsyn st.cmd.sim
You should then see something like the following:
# The is the ASYN example for communication to 4 simulated motors
# "#!" marks lines that can be uncommented.
< envPaths
epicsEnvSet("IOC","iocWithAsyn")
epicsEnvSet("TOP","/home/epics/devel/motor-6-9")
epicsEnvSet("SUPPORT","/corvette/home/epics/devel")
epicsEnvSet("ASYN","/corvette/home/epics/devel/asyn-4-31")
epicsEnvSet("SNCSEQ","/corvette/home/epics/devel/seq-2-2-4")
epicsEnvSet("BUSY","/corvette/home/epics/devel/busy-1-7")
epicsEnvSet("EPICS_BASE","/corvette/usr/local/epics-devel/base-3.15.5")
epicsEnvSet("IPAC","/corvette/home/epics/devel/ipac-2-14")
dbLoadDatabase("/home/epics/devel/motor-6-9/dbd/WithAsyn.dbd")
WithAsyn_registerRecordDeviceDriver(pdbbase)
dbLoadTemplate("motor.substitutions.sim")
motorSimCreateController("motorSim1", 4)
#asynSetTraceIOMask("motorSim1", 0, 4)
#asynSetTraceMask("motorSim1", 0, 255)
# motorSimConfigAxis(port, axis, lowLimit, highLimit, home, start)
motorSimConfigAxis("motorSim1", 0, 20000, -20000,  500, 0)
motorSimDriver:motorSimConfigAxis: configuring controller motorSim1 axis 0
motorSimConfigAxis("motorSim1", 1, 20000, -20000, 1500, 0)
motorSimDriver:motorSimConfigAxis: configuring controller motorSim1 axis 1
motorSimConfigAxis("motorSim1", 2, 20000, -20000, 2500, 0)
motorSimDriver:motorSimConfigAxis: configuring controller motorSim1 axis 2
motorSimConfigAxis("motorSim1", 3, 20000, -20000, 3000, 0)
motorSimDriver:motorSimConfigAxis: configuring controller motorSim1 axis 3
iocInit
Starting iocInit
## EPICS R3.15.5
## EPICS Base built Apr 17 2017
cas warning: Configured TCP port was unavailable.
cas warning: Using dynamically assigned TCP port 45582,
cas warning: but now two or more servers share the same UDP port.
cas warning: Depending on your IP kernel this server may not be
cas warning: reachable with UDP unicast (a host's IP in EPICS_CA_ADDR_LIST)
You can then type the "help" command to see what commands are available at the IOC shell.  The available commands depends on how your application was built.
epics> help
Type 'help <command>' to see the arguments of <command>.
#               A3200AsynConfig A3200AsynSetup  ACRCreateController
AG_CONEXCreateController        AG_UCCreateAxis AG_UCCreateController
ANC150AsynConfig                ANC150AsynSetup ClockTime_Report
ClockTime_Shutdown              ESP300Config    ESP300Setup
EnsembleAsynConfig              EnsembleAsynSetup
HXPCreateController             IM483PLConfig   IM483PLSetup    IM483SMConfig
IM483SMSetup    ImsMDrivePlusCreateController   MAXvConfig      MAXvSetup
MCB4BConfig     MCB4BCreateController           MCB4BSetup      MDriveConfig
MDriveSetup     MM3000Config    MM300Setup      MM4000AsynConfig
MM4000AsynSetup MM4000Config    MM4000Setup     MVP2001CreateAxis
MVP2001CreateController         OmsPC68Config   OmsPC68Setup    PIC630Config
PIC630Setup     PIC662Config    PIC662Setup     PIC663Config    PIC663Setup
PIC844Config    PIC844Setup     PIC848Config    PIC848Setup     PIC862Config
PIC862Setup     PIE516Config    PIE516Setup     PIE517Config    PIE517Setup
PIE710Config    PIE710Setup     PIE816Config    PIE816Setup
PI_GCS2_CreateController        PM304Config     PM304Setup      PM500Config
PM500Setup      SC800Config     SC800Setup      SMC100CreateController
SMChydraCreateController        SmartMotorConfig
SmartMotorSetup SoloistConfig   SoloistSetup
WithAsyn_registerRecordDeviceDriver             XPSAuxConfig    XPSConfig
XPSConfigAxis   XPSCreateAxis   XPSCreateController
XPSCreateProfile                XPSDisableAutoEnable            XPSDisablePoll
XPSEnableMoveToHome             XPSEnableMovingMode
XPSEnableSetPosition            XPSGathering    XPSInterpose
XPSNoDisableError               XPSSetPosSleepTime              XPSSetup
asDumpHash      asInit          asSetFilename   asSetSubstitutions
ascar           asdbdump        asphag          aspmem          asprules
aspuag          astac           asynAutoConnect asynEnable
asynInterposeEosConfig          asynInterposeFlushConfig
asynMotorEnableMoveToHome       asynOctetConnect
asynOctetDisconnect             asynOctetFlush  asynOctetGetInputEos
asynOctetGetOutputEos           asynOctetRead   asynOctetSetInputEos
asynOctetSetOutputEos           asynOctetWrite  asynOctetWriteRead
asynRegisterTimeStampSource     asynReport      asynSetAutoConnectTimeout
asynSetMinTimerPeriod           asynSetOption   asynSetTraceFile
asynSetTraceIOMask              asynSetTraceIOTruncateSize
asynSetTraceInfoMask            asynSetTraceMask                asynShowOption
asynUnregisterTimeStampSource   asynWaitConnect callbackParallelThreads
callbackSetQueueSize            casr            cd              coreRelease
date            dbDumpBreaktable                dbDumpDevice    dbDumpDriver
dbDumpField     dbDumpFunction  dbDumpMenu      dbDumpPath      dbDumpRecord
dbDumpRecordType                dbDumpRegistrar dbDumpVariable  dbLoadDatabase
dbLoadRecords   dbLoadTemplate  dbLockShowLocked                dbNotifyDump
dbPutAttribute  dbPvdDump       dbPvdTableSize  dbReportDeviceConfig
dbStateClear    dbStateCreate   dbStateSet      dbStateShow     dbStateShowAll
dba             dbap            dbb             dbc             dbcar
dbd             dbel            dbgf            dbgrep          dbhcr
dbior           dbl             dbla            dblsr           dbnr
dbp             dbpf            dbpr            dbs             dbsr
dbstat          dbtgf           dbtpf           dbtpn           dbtr
drvAsynIPPortConfigure          drvAsynIPServerPortConfigure
drvAsynMotorConfigure           drvAsynSerialPortConfigure      echo
eltc            epicsEnvSet     epicsEnvShow    epicsMutexShowAll
epicsParamShow  epicsPrtEnvParams               epicsThreadResume
epicsThreadShow epicsThreadShowAll              epicsThreadSleep
errlog          errlogInit      errlogInit2     exit
generalTimeReport               gft             help
installLastResortEventProvider  iocBuild        iocInit         iocLogInit
iocLogPrefix    iocLogShow      iocPause        iocRun          iocshCmd
iocshLoad       iocshRun        listMovingMotors
motorSimConfigAxis              motorSimCreate  motorSimCreateController
motorUtilInit   oms58Setup      pft             phytronCreateAxis
phytronCreateController         postEvent       printChIDlist   pwd
registryDeviceSupportFind       registryDriverSupportFind       registryDump
registryFunctionFind            registryRecordTypeFind
scanOnceSetQueueSize            scanpel         scanpiol        scanppl
seq             seqChanShow     seqQueueShow    seqShow         seqStop
seqcar          setIdlePollPeriod               setIocLogDisable
setMovingPollPeriod             taskwdShow      tclcall         tpn
var             xps_gathering
epics>
-----Original Message-----
From: Guilherme Jovanini Montagner [mailto:[email protected]]
Sent: Wednesday, September 13, 2017 9:04 AM
To: Mark Rivers
Cc: Ronald L. Sluiter; tech-talk
Subject: Re: Help creating motorR6-9 examples
Hello.
I mean, is the driver complete and I just need to create the st.cmd file, or is there something else to it? Also, where can I find information on writing this kind of file? What language is it written in?
Thanks for your help!
+55 19 2517.8911
+55 19 99806.9117
[email protected]
----- Mensagem original -----
De: "Mark Rivers" <[email protected]>
Para: "guilherme" <[email protected]>
Cc: "Ronald L. Sluiter" <[email protected]>, "tech-talk" <[email protected]>
Enviadas: Quarta-feira, 13 de setembro de 2017 10:14:18
Assunto: RE: Help creating motorR6-9 examples
> Let me ask you then, if I want to connect to a PI controller, do I need to create a st.cmd file that loads the right resources for that purpose?
Yes.  motor/iocBoot/iocWithAsyn contains example st.cmd.* files for a number of controllers, but I don't see any examples for a PI controller.
I think the commands you need are, for example:
drvAsynIPPortConfigure("PI", "xxx.xxx.xxx.xxx:PORT", 0, 0, 0)
PI_GCS2_CreateController("PI_MOTOR", "PI", int numAxes, int priority, int stackSize, int movingPollingRate, int idlePollingRate)
Where PI is the name of an asyn IP port driver you create, xxx.xxx.xxx.xxx is the IP address of your controller, PORT is the TCP port that the controller accepts connections on, and PI_MOTOR is the name you give to the motor controller you create.  PI_MOTOR is the name you give in your motor template file.
From: Guilherme Jovanini Montagner [[email protected]]
Sent: Wednesday, September 13, 2017 7:53 AM
To: Mark Rivers
Hello
Thank you! it worked. Now I've got a bin folder and an executable file WithAsyn within it.
Because the preinstalled files don't seem to be what i want to run.
Sorry, I'm new to EPICS and am still investigating how can we develop applications for it.
Thanks
+55 19 2517.8911
+55 19 99806.9117
[email protected]
Para: "guilherme" <[email protected]>, "Ronald L. Sluiter" <[email protected]>
Cc: "tech-talk" <[email protected]>
Enviadas: Quarta-feira, 13 de setembro de 2017 9:03:19
> Can it be because I have another folder with motorR6-8 on the machine?
No, this error is because motor R6-9 is not compatible with base 3.15 or 3.16.  PI_GCS2Support.dbd includes the motor record, which it should not do.
You can comment out these 2 lines in PI_GCS2Support.dbd
include "asyn.dbd"
include "motorRecord.dbd"
Or you can get the master branch from github, https://github.com/epics-modules/motor
I know that the master branch works on base 3.15.5, but I see that are working with base 3.16.1 and I am not sure if that has been tested with motor yet.
From: [email protected] [[email protected]] on behalf of Guilherme Jovanini Montagner [[email protected]]
Sent: Wednesday, September 13, 2017 6:51 AM
To: Ronald L. Sluiter
Cc: tech-talk
Hello again, good morning.
I've just tried that, and then, make outputs the following error:
Creating dbd file WithAsyn.dbd
perl -CSD /home/setup/Downloads/base-3.16.1/bin/linux-x86_64/dbdExpand.pl   -I. -I.. -I../O.Common -I../../../dbd -I/home/setup/Downloads/support/asyn4-31/dbd -I/home/setup/Downloads/base-3.16.1/dbd -I../../../dbd -o WithAsyn.dbd base.dbd motorSupport.dbd PI_GCS2Support.dbd
dbdExpand.pl: Duplicate definition of record type 'motor'
Context: recordtype(motor) in file '../../../dbd/motorRecord.dbd' in file '../../../dbd/PI_GCS2Support.dbd'
  while reading 'PI_GCS2Support.dbd' to create 'WithAsyn.dbd'
dbdExpand.pl: Exiting due to errors
Thanks again.
+55 19 2517.8911
+55 19 99806.9117
[email protected]
De: "Ronald L. Sluiter" <[email protected]>
Para: "tech-talk" <[email protected]>
Enviadas: Terça-feira, 12 de setembro de 2017 18:05:43
Assunto: Fwd: Re: Help creating motorR6-9 examples
-------- Forwarded Message --------
Date:   Tue, 12 Sep 2017 15:57:49 -0500
To:     Guilherme Jovanini Montagner <[email protected]>
Hello Guilherme,
I see from the makedump.txt file you sent that you are only building the
"MotorSrc" and "PIGCS2Src" directories. That is OK, but the <motor>/motorExApp
assumes that all the support directories are built.
You could follow one of two paths. One path would be to restore
motorR6-9/motorApp/Makefile to its' orginial state and rebuild.
The other, minimalist, path would be to comment out (or remove) from motorExApp
everything irrelavent to PIGCS2Src support. That requires;
- In motorR6-9/motorExApp/Makefile, comment out "DIRS += NoAsyn" (there is no
PIGCS2Src support in NoAsyn).
- Replace motorR6-9/motorExApp/WithAsyn/Makefile with the attached copy.
- rebuild
I think that should work.
Ron
On 09/12/2017 03:25 PM, Guilherme Jovanini Montagner wrote:
> Hi.
> Ok, here it is (attached)
> I'll have to go now, but I'll come back.
> Thanks!
> +55 19 2517.8911
> +55 19 99806.9117
> [email protected]
> Enviadas: Terça-feira, 12 de setembro de 2017 17:17:16
> Assunto: Re: Help creating motorR6-9 examples
> Could you run the following command at the top directory,
>> make >& makedump.txt
> and send me the file.
> Ron
> On 09/12/2017 03:13 PM, Guilherme Jovanini Montagner wrote:
>> Hi again. Yes, I have run make from the top, and after, tried running it again from the child directory.
>> +55 19 2517.8911
>> +55 19 99806.9117
>> [email protected]
>> Para: "guilherme" <[email protected]>, "tech-talk" <[email protected]>
>> Enviadas: Terça-feira, 12 de setembro de 2017 17:06:32
>> If you did not run "make" from the top level "motorR6-9" directory, that could
>> be why you are getting these errors. The EPICS motor module, like EPICS base and
>> most other EPICS modules, assumes that "make" is run 1st from the top level
>> directory. After running 'make' from the top level you can make custom changes
>> and taylor the module to your specific needs, but you should run make from the
>> top 1st.
>> Ron
>> On 09/12/2017 02:57 PM, Ronald L. Sluiter wrote:
>>> Hello Guilherme,
>>> I am guessing that the SoftMotorSrc directory did not get built. If you 'ls'
>>> the SoftMotorSrc directory you should get this;
>>>> % ls motorApp/SoftMotorSrc
>>>> devSoftAux.cc  devSoft.cc  devSoft.h  devSoftMotor.dbd Makefile  O.Common
>>>> O.linux-x86_64
>>> and there should be a 'devSoftMotor.dbd' file installed in the top 'dbd'
>>> directory.
>>>> galadriel% ls dbd
>>>> ACRMotorSupport.dbd  devDeltaTau.dbd        devMclennanMotor.dbd
>>>> devNewport.dbd  devPIJena.dbd *devSoftMotor.dbd* MicronixSupport.dbd
>>>> motorSupport.dbd         omsAsynSupport.dbd
>>>> devAcsMotor.dbd      devFaulhaberMotor.dbd  devMicos.dbd devOms.dbd
>>>> devPIMotor.dbd      devSPiiPlus.dbd motorRecord.dbd      NoAsyn.dbd
>>>>         phytron.dbd
>>>> devAerotech.dbd      devImsMotor.dbd        devMicroMo.dbd devOriel.dbd
>>>> devSmarActMCSMotor.dbd  devThorLabs.dbd motorSim.dbd         NoAsynVx.dbd
>>>>         PI_GCS2Support.dbd
>>>> devAttocube.dbd      devKohzuMotor.dbd        devNewFocus.dbd
>>>> devPC6K.dbd      devSmartMotorMotor.dbd  HytecMotorDriver.dbd
>>>> motorSimSupport.dbd  NPointMotorSupport.dbd
>>> What do you see in those two directories?
>>> Ron
>>> On 09/12/2017 02:25 PM, Guilherme Jovanini Montagner wrote:
>>>> Hi!
>>>> I'm involved in a Project in which EPICS is to be used, and am currently
>>>> trying to create a working example using a PI piezo controller.
>>>> I want some help doing this.
>>>> I've uncommented the lines
>>>> DIRS += motorExApp iocBoot
>>>> motorExApp_DEPEND_DIRS = motorApp
>>>> iocBoot_DEPEND_DIRS = motorExApp
>>>> from the top makefile. I've also uncommented the line "MOTOR=$(TOP)" in
>>>> configure/RELEASE file
>>>> Also, on the file motorApp/Makefile, I've got the lines
>>>> DIRS +=PIGCS2Src
>>>> PIGCS2Src_DEPEND_DIRS = MotorSrc
>>>> uncommented.
>>>> The problem is, when I run make on top, I get the following message:
>>>> [setup@localhost motorExApp]$ make
>>>> make -C ./NoAsyn install
>>>> make[1]: Entering directory
>>>> `/home/setup/Downloads/support/motor/motorR6-9/motorExApp/NoAsyn'
>>>> make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
>>>>       T_A=linux-x86_64 install
>>>> make[2]: Entering directory
>>>> `/home/setup/Downloads/support/motor/motorR6-9/motorExApp/NoAsyn/O.linux-x86_64'
>>>> Creating dbd file NoAsyn.dbd
>>>> -I/home/setup/Downloads/base-3.16.1/dbd -o NoAsyn.dbd base.dbd
>>>> motorRecord.dbd devSoftMotor.dbd Misc.dbd
>>>> dbdExpand.pl: Can't find file 'devSoftMotor.dbd'
>>>>     while reading 'devSoftMotor.dbd' to create 'NoAsyn.dbd'
>>>>     Your Makefile may need this dependency rule:
>>>>       $(COMMON_DIR)/NoAsyn.dbd: $(COMMON_DIR)/devSoftMotor.dbd
>>>> make[2]: *** [../O.Common/NoAsyn.dbd] Error 255
>>>> make[2]: Leaving directory
>>>> make[1]: *** [install.linux-x86_64] Error 2
>>>> make[1]: Leaving directory
>>>> make: *** [NoAsyn.install] Error 2
>>>> Then, I proceeded to add the mentioned line on motorExApp/NoAsyn/Makefile:
>>>>    ADD MACRO DEFINITIONS AFTER THIS LINE
>>>> PROD_IOC_DEFAULT = NoAsyn
>>>> PROD_IOC_vxWorks = NoAsynVx
>>>> COMMONDBDS  = base.dbd
>>>> COMMONDBDS += motorRecord.dbd
>>>> COMMONDBDS += devSoftMotor.dbd
>>>> #!COMMONDBDS += devMXmotor.dbd
>>>> but when I run make again, after doing that, I get the following error:
>>>> Creating dbd file devSoftMotor.dbd
>>>> -I/home/setup/Downloads/base-3.16.1/dbd -o devSoftMotor.dbd
>>>> dbdExpand.pl: No input files for devSoftMotor.dbd
>>>> make[2]: *** [../O.Common/devSoftMotor.dbd] Error 255
>>>> I don't know where is this devSoftMotor.dbd being called, and why it doesn't
>>>> have input arguments.
>>>> Could you help me, please?
>>>> Thanks,
>>>> Guilherme
>>>> *Guilherme Jovanini Montagner*
>>>> +55 19 2517.8911
>>>> +55 19 99806.9117
>>>> [email protected]
Re: Help creating motorR6-9 examples Guilherme Jovanini Montagner
Fwd: Re: Help creating motorR6-9 examples Ronald L. Sluiter
RE: Help creating motorR6-9 examples Mark Rivers
Prev: Re: Questions regarding CA protocol specification and phylosophy Diego Sanz
Next: Re: Questions regarding CA protocol specification and phylosophy Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: Re: Help creating motorR6-9 examples Guilherme Jovanini Montagner
Next: Re: Help creating motorR6-9 examples Guilherme Jovanini Montagner
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
